    Stepper motor hissing sound while moving
    • adhanabal
      adhanabal last edited by
      Hi
      I configured my duet mastero and tested the motors, all the motors are Nema17 - 1.2amps rated, i use 24v system, Motors moves in correct direction,
      Problem is While idle motor has no hissing sound , but when moving very high hissing sound happens, what can i do to avoid this?
      M92 X100.00 Y100.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z300 E1200 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z600 E1200 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
        A hissing sound from the stepper motors isn't uncommon and is nothing to worry about. It depends on the combination of stepper drivers, motors, and power voltage.
        There are two reasons why it's quieter at standstill than when moving:
        • First, the stepper drivers apply standstill current reduction. This is settable using M917 and it defaults to 75%.
        • Second, by default the drivers use stealthChop mode when at standstill but switch to spreadCycle at quite a low movement speed. You can increase that transition speed so that the drivers are in stealthChop mode during normal printing. Doing so increases the risk of missed steps, because in stealthChop mode the drivers can't react to sudden increases in load, such as when the nozzle encounters a blob or overhang that needs extra force to traverse. If you want to try increasing the transition speed, see the V parameter of the M569 command, https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing.
        • adhanabal
          thank you, my doubt is the noise is too high , like releasing a compressed air, i never had this issue on my previous machines, this is the first time im encountering this.
            What are your motors? Which Duet?
            • bot
              bot last edited by
              Are your belts rubbing against something, like the lip of the pulleys or idlers? Is there something contacting the rotating shafts of the motor or other moving parts that could cause the noise?
              *not actually a robot
