    error in bed.g kossel
    Beta Firmware
    • apak
      apak last edited by
      ; Auto calibration routine for large delta printer
      M561                    ; clear any bed transform
      ; If the printer hasn't been homed, home it
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
        G28
      ; Probe the bed and do auto calibration
      G1 X0 Y89.9 Z10 F10000        ; go to just above the first probe point
      while true
        if iterations = 5
          abort "Too many auto calibration attempts"
        G30 P0 X0 Y89.9 H0 Z-99999
        if result != 0
          continue
        G30 P1 X77.86 Y44.95 H0 Z-99999
        if result != 0
          continue
        G30 P2 X77.86 Y-44.95 H0 Z-99999
        if result != 0
          continue
        G30 P3 X0 Y-89.9 H0 Z-99999
        if result != 0
          continue
        G30 P4 X-77.86 Y-44.95 H0 Z-99999
        if result != 0
          continue
        G30 P5 X-77.86 Y44.95 H0 Z-99999
        if result != 0
          continue
        G30 P6 X0 Y44.9 H0 Z-99999
        if result != 0
          continue
        G30 P7 X38.88 Y-22.45 H0 Z-99999
        if result != 0
          continue
        G30 P8 X-38.88 Y-22.45 H0 Z-99999
        if result != 0
          continue
        G30 P9 X0 Y0 Z-99999 S6
        if result != 0
          continue
        if move.calibration.final <= 0.03
          break
        echo "Repeating calibration because deviation is too high (" ^ move.calibration.final ^ "mm)"
      ; end loop
      echo "Auto calibration successful, deviation", move.calibration.final ^ "mm"
      G1 X0 Y0 Z150 F10000                ; get the head out of the way
      gives me error:
      Calibrated 6 factors using 10 points, (mean, deviation) before (0.003, 0.050) after (0.000, 0.040)
      Error: in file macro line 43 column 36: G30: expected numeric operand
      it´s the line
      what should I do...it was working fine
      RRF 3.01RC4
      Danal 1 Reply Last reply Reply Quote 0
      • Danal
        Danal @apak last edited by Danal
        @apak said in error in bed.g kossel:
        Was working on RC3?
        Anyway... even though it was working, sounds like the parser changed a little bit. I'd try things that achieve the same result, using different symbols, just for debugging.
        Example 1:
        if move.calibration.final < 0.031
        Example 2:
          break
        if move.calibration.final = 0.03
          break
        Example 3: (I am less sure about the exact syntax on this one)
        if ! {move.calibration.final > 0.03}
          break
        You get the idea.
        • apak
          apak last edited by apak
          @Danal said in error in bed.g kossel:
          Example 1 console:
          	G32
          Calibrated 6 factors using 10 points, (mean, deviation) before (-0.370, 0.048) after (-0.000, 0.018)
          0
          Error: in file macro line 44 column 36: G30: expected numeric operand
          Example 3 console:
          0
          Repeating calibration because deviation is too high ({object}mm)
          Calibrated 6 factors using 10 points, (mean, deviation) before (-0.004, 0.020) after (-0.000, 0.020)
          0
          G32
          Calibrated 6 factors using 10 points, (mean, deviation) before (-0.004, 0.027) after (-0.000, 0.023)
          0
          Warning: both space and tab characters used to indent blocks by line 44Repeating calibration because deviation is too high ({object}mm)
          This enters in a loop and keeps on going. I have to stop it.
          The 0 value is because I inserted an "Echo result after S6"
          So, example 1 (and previous code) do break the while, because it´s under 0.03, but can´t print the value and shows {object} instead.
          example 3, does a loop.
          • Danal
            Danal last edited by
            That makes it pretty clear the error is not with "<=" which was one of my suspects if this is a parser change.
            Given the results you are getting, I would continue to try "equivalent" statements of various kinds... but I would also take all the text in this file, copy it out to an editor that shows tabs, spaces, and trailing spaces separately clean up any such stuff, and put it back in the file.
            Meaning, I am now suspecting something we "can not see" when looking at the code. Space, Tab, Line End, etc, etc.
            And/or download the file, and attach it as I file here. (All file handling, not text copy/paste) and I will run it on my big delta.
            • apak
              got it:
                G28
              while true
                if iterations = 5
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if ! {move.calibration.final.deviation > 0.03}
                  break
                echo "Repeating calibration because deviation is too high (" ^ move.calibration.final.deviation ^ " mm)"
              ;end loop
              echo "Auto calibration successful, deviation "^ .deviation ^ "mm"
              It´s the object...move.calibration.final.deviation instead of move.calibration.final
              my original file also worked one added de ".deviation" to the object "move.calibration.final"
                G28
              while true
                if iterations = 5
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if result != 0
                  continue
                if move.calibration.final.deviation <= 0.03
                  break
              ;end loop
              echo "Auto calibration successful, deviation "^ move.calibration.final.deviation ^ "mm"
              • apak
                apak last edited by
                console after the change:
                G32
                Calibrated 6 factors using 10 points, (mean, deviation) before (0.001, 0.023) after (0.000, 0.022)
                Auto calibration successful, deviation 0.022mm
                • Danal
                  Wooo Hooo!!! Good find.
                  The object model DID change. 🙂
