    Radial coordinate system
    98
    • gnydick
      gnydick last edited by
      If I want to build a machine that moves to cover a circular area, but need it to be extremely thin, I would want a turntable and arm of some sort. Is that type of kinematic supported?
        You mean like a Polar coordinate printer?
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwarePolarPrinter
        gnydick 1 Reply Last reply Reply Quote 0
        • gnydick
          gnydick @Phaedrux last edited by
          @Phaedrux yes, thanks. Though I don't want to make a printer, I want to make something else entirely.
          • Danal
            Danal last edited by
            I've also been working with an ESP32 motion controller that supports either conventional SCARA or turntable/arm (or Cartesian). Nowhere near as fancy as the Duet... but does great with two TMC drive chips for its specialized purpose.
            Full motion control, accel, deccel, etc. G-Code interpreter. Rho-Theta interpreter (for that circular stuff).
            If you have a project you don't want to fully discuss on the forum, email me:
            danal (dot) estes (at) gmail (dot) com
            You still don't have to reveal anything detailed... I can point you at the origin of the ESP32 controller that I'm talking about, and discuss my roadmap of planned refinements. Reasonably possible it might already do what you are seeking.
            gnydick 1 Reply Last reply Reply Quote 1
            • gnydick
              gnydick @Danal last edited by
              @Danal it's fine. I want to make my own self drawing sand table. Where the ball bearing draws patterns in the sand slowly over time.
              • Danal
                That's exactly what the ESP32 controller is for. A Sisyphus style sand table.
                • Danal
                  This is the scara version. Bar/turntable is also supported.
                  I built a prototype, and the movement works quite well... however, I can't seem to find a magnet/ball/sand combination that moves smoothly. I haven't had much time to try different combinations.
                  • Danal
                    Since this is not really Duet related, where is a good place to move this discussion?
                      dc42 administrators @Danal last edited by
                      @Danal said in Radial coordinate system:
                      The Off Topic category, https://forum.duet3d.com/category/26/off-topic.
                        How 'bout wider discussion?
