    Solved Heated Bed Max Temperature Issue
    • lee7670
      lee7670 last edited by
      Hello, ever since updating to RRF 3.01RC3 on my Duet 3, I've been having an issue where my max heated bed heater temperatures (there are 2 heaters and sensors) are not being set correctly. I try to set a temperature higher than 125 and the board spits out a temperature too high for heater error.
      I have copied the relevant section of my config.g below.
      M308 S0 P"temp0" Y"pt1000" A"Bed Right Rear" R2200         ; configure sensor 0 as PT1000 on pin temp0
      M950 H0 C"out7" T0                       ; create bed heater output on out7 and map it to sensor 0
      M143 H0 P0 S200 A2 C-1                            ; set temperature limit for heater 0 to 200C
      M307 H0 B0 S1.00                         ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S2 P"temp2" Y"pt1000" A"Bed Left Rear" R2200
      M950 H2 C"out8" T2
      M143 H2 P0 S200 A2 C-1
      M307 H2 B0 S1.00
      M140 P1 H0
      M140 P2 H2
      Thank you!
        Try moving the M143 commands for the bed heaters after the corresponding M140 commands. Either the M307 command or the M140 command is resetting the temperature limit.
        • lee7670
          Great! That fixed it, but now my Duet Web Control graphs go up to 2000 degrees for some reason.
          Here's the new section.
          M140 P1 H0
          M140 P2 H2
          And here's what my temperature graph looks like.
          Thanks!
          dc42 cryptelli 2 Replies Last reply Reply Quote 0
            dc42 administrators @lee7670 last edited by
            @lee7670 said in Heated Bed Max Temperature Issue:
            Please post your whole config.g file, also config-override.g if you use it.
            • cryptelli
              cryptelli @lee7670 last edited by
              @lee7670 I'm also facing this issue. Please see below for my config.g. Any ideas @dc42?
              ; Configuration file for My Printer
              ; Communication and general
              M111 S0                             	; Debug off
              M550 PRailCore				; Machine name and Netbios name (can be anything you like)
              ;M551 Pmyrap                        	; Machine password (used for FTP)
              ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
              ;M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEE 	; MAC Address
              ;*** Wifi Networking
              M552 S1								; Enable WiFi
              M555 P2                           	; Set output to look like Marlin
              M575 P1 B57600 S1					; Comms parameters for PanelDue
              G21                                 	; Work in millimetres
              G90                                		; Send absolute coordinates...
              M83                                 	; ...but relative extruder moves
              ; Axis and motor configuration
              M669 K1								; _RRF3_ change M667 to M669 ; set CoreXY mode
              M584 X0 Y1 Z5:6:7 E3:4:8:9 		; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders
              M569 P0 S0                          ; Drive 0 goes forwards (change to S0 to reverse it) X stepper (Rear)
              M569 P1 S1                          ; Drive 1 goes backwards	Y Stepper (Front)
              M569 P2 S1                          ; Drive 2 goes forwards		Unused
              M569 P3 S1                         ; Drive 3 goes forwards		Extruder
              M569 P4 S1                          ; Drive 4 goes forwards		Extruder (unused)
              M569 P5 S0							; Drive 5 goes backwards	Front Left Z
              M569 P6 S0							; Drive 6 goes backwards	Rear Left Z
              M569 P7 S0							; Drive 7 goes backwards	Right Z
              ;Leadscrew locations
              M671 X-10:-10:333  Y22.5:277.5:150 S7.5  ;Front left, Rear Left, Right  S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
              ;M671 X-8.97:-8.97:351  Y20:277:150 S7.5  ;Front left, Rear Left, Right  S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
              M350 X16 Y16 Z16 E16 I1	    ; set 16x microstepping for axes& extruder, with interpolation
              ;_RRF3_ comment out: M574 X1 Y1 Z0 S1
              M574 X1 S1 P"xstop"			; _RRF3_ set X endstop to xstop port active high
              M574 Y1 S1 P"ystop"			; _RRF3_ set Y endstop to ystop port active high
              M906 X1400 Y1400 Z1000 E800 I60	    ; Set motor currents (mA)
              M201 X3000 Y3000 Z100 E1500          ; Accelerations (mm/s^2)
              M203 X24000 Y24000 Z900 E3600      ; Maximum speeds (mm/min)
              M566 X1000 Y1000 Z100 E1500            ; Maximum jerk speeds mm/minute
              M208 X295 Y295 Z335                 ; set axis maxima and high homing switch positions (adjust to suit your machine)
              M208 X0 Y0 Z-0.5 S1                 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
              M92 X200 Y200 Z1600 E837	    ; steps/mm
              ; Thermistors
              ;_RRF3_ comment out: M305 P0 T100000 B3950 R4700 H0 L0	; Put your own H and/or L values here to set the bed thermistor ADC correction
              M308 S0 P"bedtemp" Y"thermistor" A"bed_heat" T100000 B3950 R4700 H0 L0 		;_RRF3_ Bed thermistor, connected to bedtemp on Duet2
              M140 H0
              M143 H0 S120
              ;If you have a Slice Engineering thermistor, comment out the next line
              ;_RRF3_ comment out: M305 P1 T100000 B4725 R4700 H0 L0 C7.06e-8	; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
              M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T100000 B4725 R4700 C7.06e-8 H0 L0	;_RRF3_ duet3 e3d
              M143 H1 S300
              ;If you have a Slice Engineering thermistor, uncomment the next lines.  KITS DO NOT SHIP WITH A SLICE THERMISTOR - ONLY UNCOMMENT IF YOU ORDERED ONE
              ;M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T500000 B4723 R4700 C1.196220e-7	;_RRF3_ slice thermistor
              M950 H0 C"bedheat" T0				;_RRF3_ define Bed heater is on bedheat
              M950 H1 C"e0heat" T1				;_RRF3_ define Hotend heater is on e0heat
              ;M307 H0 A240.3 C608.7 D8.2 S1.00 V24.1 B0 ; Bed Heaters
              M307 H0 R0.386 C932.8 D25.26 S1.00 V24.3
              ;M307 H1 A270.7 C90.4 D6.7 B0 S1.0	;Heater 1 model
              M307 H1 R1.973 C215.2 D4.99 S1.00 V24.3
              M570 S360				; Hot end may be a little slow to heat up so allow it 180 seconds
              M950 F0 C"fan0"						;_RRF3_ define fan0
              M950 F1 C"fan1"						;_RRF3_ define fan1
              M950 F2 C"fan2"						;_RRF3_ define fan2
              M106 P0 H-1 				; disable thermostatic mode for fan 0
              M106 P1 H-1 				; disable thermostatic mode for fan 1
              M106 P2 H-1
              M106 P0 S0 				; turn off fans
              M106 P1 S0
              M106 P2 S0
              ; Tool definitions
              M563 P0 D0 H1                       	; Define tool 0
              G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
              ;*** If you have a single-nozzle build, comment the next 2 lines
              ;M563 P1 D1 H2                      	; Define tool 1
              ;G10 P1 S0 R0 X0 Y17                    	; Set tool 1 operating and standby temperatures
              ; Z probe and compensation definition
              ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
              ; IR PRobe - uncomment the following 2 lines if you have a and IR Probe, and comment out the BLTouch section below
              ;RRF3 IR Probe only comment out: M558 P1 X0 Y0 Z1			; Z probe is an IR probe and is not used for homing any axes
              ;M558 P1 C"^zprobe.in" H5 F120 T6000 A5 S0.02  ; _RRF3_ IR Probe connected to Z probe IN pin
              ;G31 X0 Y30 Z2.00 P500			; Set the zprobe height and threshold (put your own values here)
              ;BLTouch - comment out the following 3 lines if using a IR Probe
              ;_RRF3_ comment out: M307 H3 A-1 C-1 D-1
              ;_RRF3_ comment out: M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
              M558 P9 C"^zprobe.in" H5 R1 F50 T6000 A5 S0.02  ; _RRF3_ BLTouch connected to Z probe IN pin
              M950 S0 C"duex.pwm1"				   ; _RRF3_ Define BLTouch Servo (S0) on duet pwm1
              G31 X2 Y42 Z1.84 P25 ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
              T0					; select first hot end
                Phaedrux Moderator @cryptelli last edited by
                @cryptelli I suggest you go back to the online config tool and generate a config to compare yours against. The ordering of the heater commands for instance.
                M308 S0 P"temp0" Y"thermistor" T100000 B3950          ; configure sensor 0 as thermistor on pin temp0
                M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
                M140 H0                                               ; map heated bed to heater 0
                M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
                M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                cryptelli 1 Reply Last reply Reply Quote 0
                • cryptelli
                  cryptelli @Phaedrux last edited by
                  @phaedrux Yea. Ended up doing that, problem solved.
