    PT100 Sensor on thermocouple daughter board ?
    • EricD
      EricD last edited by
      Hello all,
      Is PT100 sensor can be connected on a thermocouple daughter board ?
      I am afraid not but I ask the question 😉 .
      I have only the thermocouple daughter board on stock yet (and it is difficult to order something with this f...ing virus).
      Stay safe,
      Eric
        No, a PT100 sensor cannot be used with a thermocouple board. Many of our distributors have stocks of the PT100 board.
        • A Former User
          A Former User last edited by
          could try this while you wait, but do take note its a poor solution, I only used it for a chamber sensor with no heater.
          dc42 said in Controlling a Cetus3D with Duet3D 0.8.5:
          fotomas said in Controlling a Cetus3D with Duet3D 0.8.5:
          cookie
          I'm using the original cetus thermistor. It works well after finding the correct values for it.
          I do not think a negative B value is common.
          M305 P1 R4700 T112 B-425 C7.060000e-8
          Looks like you are using a PT100 but you have connected it directly to the thermistor input. This will give you a very poor resolution and you should use the PT100 daughter board instead. However, if you want to use a direct connection then I suggest this:
          M305 P1 X501 R47000
          This says you are using a PT1000 sensor, but inflates the series resistor value by a factor of 10 to compensate for the fact that you are actually using a PT100.
