    Spurious heater fault during heating chamber
    • Jap
      Jap last edited by
      I have faced heater faults when I turn chamber heater on and leave E0&E1 to 0C for eg. to dry filaments etc.
      During the chamber heating E0 & E1 rises also, even not heated by their own heaters and at some point they will report error. I have M570 set to 15C.
      By looking the pinned spurious heater fault topic there is a mention that heater monitoring is activated >45C.
      Basic options would be:
      1. Also put heater on for E0&E1 to same as chamber temp
      2. Widen M570 excursion limit so temps in E0&E1 does not exceed the limit.
      Is that 45C / temp monitoring limit hard coded? can it be changed?
      Do you have ideas how to avoid this without need to but heaters on or modify M570 limits?
      -jap
        Why not set the extruders temperatures equal to the target chamber temperature, or a little higher?
        Jap 1 Reply Last reply Reply Quote 0
        • Jap
          Jap @dc42 last edited by
          @dc42 Yes that is what I´ve been doing so far. Just asking if there is a possibility to set that monitoring temp to eg. 100C or something else that I could avoid this completely. I know that´s not a big deal to set those manually, but..
            The temperature at which monitoring starts is hard coded, so you would need to build the firmware yourself to change it.
            • Jap
              @dc42 Thanks for quick and prompt reply. I´ll move on with the old style 🙂
