    Maestro Mounting & Cooling Concept
    • CCS86
      CCS86 last edited by
      Hey guys,
      I'm gearing up to replace the simple mounting standoffs with this design I am working on. It will provide 15mm of standoff height, serve as a mounting platform for an 80mm fan, keep airflow contained under the board, and offer some cable management as well.
      Any suggestions on room for improvement or areas of concern?
      • Danal
        Danal last edited by
        Looks good. You are correctly cooling the drivers from the "bottom" of the board. I use a similar, somewhat less fancy, setup on my big Delta with a Duet2 Wifi.
        I'm sure you can imagine the rest, just from this:
        • nhof
          nhof last edited by
          May want to ensure there's enough space to get the SD card out if you need (it looks like there might be clearance already)
          CCS86 1 Reply Last reply Reply Quote 0
          • CCS86
            CCS86 @nhof last edited by
            @nhof said in Maestro Mounting & Cooling Concept:
            Good call!
            There was just barely enough room (16mm space, for a 15mm long SD). I went ahead and added 5mm more for easier access.
