    Endstops not working after FW upgrade to 3.01-RC4
    Firmware installation
    337
    • pro3d
      pro3d last edited by pro3d
      I updated from RC3 to RC4 and then I get this error in the picture.
      M119
      Endstops - X: no endstop, Y: no endstop, Z: no endstop, Z probe: not stopped
      Optical endstops set active high
      M574 X1 Y1 S1 ; Set active high endstops
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      pro3d Danal 2 Replies Last reply Reply Quote 0
      • pro3d
        pro3d @pro3d last edited by
        Solved
        M574 X1 S1 P"xstop" ; X min active high endstop switch
        M574 Y1 S1 P"ystop" ; Y min active high endstop switch
        • pro3d
          Now suddenly my layerfan does not work.... 😮
          • SIam
            SIam last edited by
            please post your config.g file
            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
            Duet WiFi 1.02 or later + DueX5
            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
            Duet WiFi Server: 1.26
            Duet Web Control 3.4.0beta4 (2021-09-27)
            pro3d 1 Reply Last reply Reply Quote 0
            • pro3d
              pro3d @SIam last edited by
              @SIam
              I sorted it out after reading a lot of Gcode
              There are so many changes from RRF2 to RRF3-RC4 so the config.g file was no longer usable
              • I thought upgrading FW took care of all this stuff
              droftarts Danal 2 Replies Last reply Reply Quote 0
              • droftarts
                droftarts administrators @pro3d last edited by droftarts
                @pro3d Are you sure you were on 3.01-RC3 before? Maybe it was one of the 3.0 betas or 3.0 RC2? Because the change that would cause this was introduced with 3.01 beta1, and that was:
                If upgrading a Duet WiFi/Ethernet/Maestro from the 3.0 release, note that default fans are no longer created. Unless your config.g file already used M950 to create the fans explicitly, add commands M950 F0 C"fan0", M950 F1 C"fan1" and M950 F2 C"fan2" to config.g before your M106 commands. Likewise, default endstop switches are not set up, so you will need to set up X and Y endstops (and Z if needed) explicitly, using one M574 line for each, and specifying the port name. Example: M574 X1 S1 P"xstop".
                https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-301beta1
                Always a good idea to read the update notes, particularly on new, rapidly developing firmware! This decision was taken as a result of this thread: https://forum.duet3d.com/topic/13720/sequence-definition-fan-pins
                The RRF config tool has been updated to generate all pin assignments, so you could always use that: https://configtool.reprapfirmware.org/
                Also, this page explains the differences between RRF 2 and 3: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                pro3d 2 Replies Last reply Reply Quote 1
                • Danal
                  Danal @pro3d last edited by Danal
                  @pro3d said in Endstops not working after FW upgrade to 3.01-RC4:
                  Never.
                  Upgrading firmware never changes your config.g. If the newer firmware needs something different, you must make that update yourself.
                  • Danal
                    Not sure which you meant to say, or what actually happened... but if you were truly move from 2.anything to 3.anything, that does indeed require quite a bit of change to config.g.
                    • pro3d
                      pro3d @droftarts last edited by
                      @droftarts
                      I am sure I was on RRF 3-RC3 stable so it was very weird. I did now do the config tool to get all the latest parameters and everything should be good - except temp issue somehow out of order. I made a new fan shroud and will do more testing
                      Thanks for the follow up
                      • pro3d
                        @droftarts
                        I now just wonder how to probe bl touch multiple times as before?
                        OLD CODE
                        ; M558 P9 C"zprobe.in" H5 F120 T6000 A30 S0.02 ; Set Z probe type to bltouch and the dive height + speeds
                        NEW CODE:
                        M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T18000 ; set Z probe type to bltouch and the dive height + speeds
                          A30 S0.02
                          Add this from your old code to your new code.
                            dc42 administrators @pro3d last edited by dc42
                            @droftarts
                            RRF 3.0 created some default endstops and fans, to try to smooth the upgrade path from RRF2. But that caused issue for some users. So as described in the upgrade notes for 3.01beta1, in RRF 3.01 no default devices are created:
