Maestro: 12v Fans A & B
Hi guys,
I am running ym Maestro on 24v and will be converting over to 12v for the fans, since I already have a buck installed.
It looks quite simple, as drawn here:
My question is that since I want (1) print cooling fan, and (2) thermostatic fans (hotend & Maestro board), I have to use the Fan2 connector and that appears to be on a separate circuit.
Do I just split the 12v hot lead and send it to the middle pin on both FanA & FanB selectors?
@CCS86 said in Maestro: 12v Fans A & B:
Yes, if all the fans will be 12V.
