Assign end stop as temp sensor and fan output as heater
  • I read that it is possible to assign a fan output as a heater output but how do one know what frequency to use? I would assume it would require using an external mosfet to handle the load as well.
    Is it possible to assign endstop as additional temp sensor? I have a duex5 and duet 2.
  • Endstops are on/off devices, temperature sensors are analog devices.Completely different animals .... so no
    Yes you could run a fan output to drive an SSR if you so desired.
    SSR's run well at 10 Hz but if I was using a fan output I would probably configure it as an on/off (bang-bang) kind of device. Others might have a better handle on this though.
    Edit: Thinking about this some more ... you want to control the heater with pwm, the frequency is a side effect (having difficulty expressing myself). I really can't see how this could be done through the fan port ... but then there are some clever people here so who knows
  • @jens55
    then what solution is there if I need additional temperature sensors for a thermistor?
  • Can't really help with that but if you have maxed out the Duet2 and Duex5 combo, I think your next step would be to go with a Duet3 setup. Again though, I have no knowledge in that area.
  • @jens55 darn it. I was thinking maybe the next step was getting a pt100 daughterboard.
  • I am not sure how the daughter boards fit into things. Somebody else will need to chime in.
  • As per documentation, pt100 duaghterboard should work fine, on Duet as well as on Duex. Of course you need pt100 sensor with it.
  • @aidar said in Assign end stop as temp sensor and fan output as heater:
    Yes, I did read that it will require the pt100 sensor. Not a problem.
    @jens55 said in Assign end stop as temp sensor and fan output as heater:
    SSRs work OK at low PWM frequencies, e.g. 10Hz for a bed or chamber heater.
  • @dc42 yes. A chamber or bed heater was the original purpose.
    David, can you confirm if there is no other way to get additional temp sensor before I need to purchase a pt100 daughterboard and a pt100 sensor?
  • This post is deleted!
    @tekstyle said in Assign end stop as temp sensor and fan output as heater:
    Are you already using all 3 thermistor inputs on the Duet, and all 5 on the Duex5?
    You can possibly use the Z probe input as a thermistor input (I haven't tested it), but you would need to add an external reference resistor.
  • @dc42 said in Assign end stop as temp sensor and fan output as heater:
    I am using all 3 thermistors and 5 on the duex5. I am using a zprobe as well for z min. I believe the zprobe-mod pin is unused at the moment.
