    DWC not available while running mesh probe routine
    128
    • gnydick
      gnydick last edited by
      Title says it all. I feel like I've seen this in other threads.
      Duet 2 Eth, rrf 3. I will post exact versions when it starts responding again.
      • Danal
        Danal last edited by
        Long running Gcode commands will cause DWC to not issue any further gcode commands.
        It should update things like coordinates and temperatures.
        What releases?
        gnydick 1 Reply Last reply Reply Quote 0
        • gnydick
          gnydick @Danal last edited by
          @Danal no, no. It's D E A D... dead. I was able to telnet and ftp in.
          While telnet'd in the HTTP server showed as enabled, but port 80 was "connection refused". So I disabled and re-enabled the HTTP server and it came back.
          Here are the diagnostic messages while it was dead. These were retrieved via telnet.
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet Ethernet 1.02 or later + DueX5
          Board ID: 08DGM-917DA-G4MS8-6J9DJ-3SD6M-KVSVA
          Used output buffers: 2 of 24 (24 max)
          Static ram: 30516
          Dynamic ram: 92740 of which 0 recycled
          Exception stack ram used: 608
          Never used ram: 7208
          Tasks: NETWORK(ready,640) HEAT(blocked,1240) DUEX(suspended,160) MAIN(running,1048) IDLE(ready,156)
          Owned mutexes:
          Last reset 21:18:09 ago, cause: software
          Last software reset at 2020-03-30 23:23, reason: User, spinning module GCodes, available RAM 7364 bytes (slot 1)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
          Error status: 4
          Free file entries: 9
          SD card longest block write time: 25.0ms, max retries 0
          MCU temperature: min 35.7, current 38.5, max 43.8
          Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 1: standstill, SG min/max 0/1023
          Driver 3: standstill, SG min/max 0/1023
          Driver 5: standstill, SG min/max 0/1023
          Driver 6: standstill, SG min/max 0/1023
          Driver 7: standstill, SG min/max 0/1023
          Driver 8: standstill, SG min/max not available
          Driver 9: standstill, SG min/max not available
          Date/time: 2020-03-31 20:42:03
          Slowest loop: 117.48ms; fastest: 0.09ms
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 128, MaxWait: 45255360ms
          === MainDDARing ===
          Scheduled moves: 1765, completed moves: 1765, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          === AuxDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          Heater 0 is on, I-accum = 0.1
          Heater 1 is on, I-accum = 0.7
          Segments left: 0
          Stack records: 3 allocated, 0 in use
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 144.41ms; fastest: 0.02ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2)
          HTTP sessions: 0 of 8
          Interface state 5, link 100Mbps full duplex
          • droftarts
            droftarts administrators @gnydick last edited by
            @gnydick What DWC version?
            • gnydick
              gnydick @droftarts last edited by
              @droftarts it's not the dwc. It's the http server that died. Trust me, I did the network diagnostics.
              droftarts A Former User 2 Replies Last reply Reply Quote 0
              • droftarts
                @gnydick said in DWC not available while running mesh probe routine:
                Trust me,
                You haven't been infallible in the past! Please just tell me what DWC version you use.
                If you could supply the network diagnostics, that might help either @dc42 or @chrishamm diagnose the issue. I can't replicate the issue, at least not with 3.01-RC5.
                In your M122 response:
                Error status: 4
                Equates to 'Output buffer starvation'.
                • gnydick
                  @droftarts I did. I described it in the post. I know nobody is perfect. But if I say I've diagnosed network connectivity, you can assume what I'm saying is as reliable as the person that invented networking. It's that much a part of what I do for a living.
                  Doestcpdump have any meaning to you? If so, you'll know where I'm coming from.
                  • Danal
                    Danal last edited by Danal
                    Is there a possibility that a given release of DWC might provoke the HTTP server into failing, and a different release might not?
                    • droftarts
                      @gnydick you still haven’t said which version of DWC you’re using. It’s a simple question, and may be useful information. It’s not reported in M122; only the firmware version is.
                      • A Former User
                        A Former User @gnydick last edited by
                        This ought be good..
                          You've got 3.0 installed. That release comes with DWC 2.0.4. Have you updated to 2.0.7?
                          • A Former User
                            A Former User last edited by
                            if you run M111 it'll list he available debug options, pick the code for the webserver and run M111 Pn S1to enable debugging for the webserver and log the serial console leading up to the next event. although if you're planning on saying "it looks good trust me" then don't bother.
                            • gnydick
                              @droftarts it doesn't matter what version of dwc is installed. DWC runs entirely in your browser and makes steady queries of your duet for status updates.
                              The HTTP server runs in the hardware on the board. It is what responds to DWCs requests.
                              Since the HTTP server dies, the DWC just behaves as if there was a firewall blocking your traffic. The DWC won't even load because the printer is actively rejecting the TCP connection. It is still reachable via TELNET and FTP.
                              I'm trying to make it clear without being rude that you most likely don't understand the subject matter. I'm providing concise information that cannot be misinterpreted unless you don't understand it.
                              Please stop pressing this issue.
                              • gnydick
                                gnydick @Phaedrux last edited by
                                @Phaedrux I don't use the new interface, it's abysmal.
                                • gnydick
                                  I issued "G29" via the TELNET interface and the HTTP immediately locked.
                                  It generated a large list is points to be skipped, I'm guessing that payload was too big to be bundled into one message and POOF.
                                  • A Former User
                                    and you're still running 3.0?
                                    • droftarts
                                      @gnydick so you’re using DWC 1.22.6 with RRF 3.0. Since you have now explained what might have caused the crash, we now need your config.g and bed.g if used to see bed and machine limits, probe offset and M557 command it uses to generate probe points. This should show how many points were generated, spurious or not, that probably caused the error seen in M122, and possibly the web server crash. Or just say how many probe points you were trying to measure. Need this information to replicate the issue, so we can see why the web server crashed.
                                      FYI you should run G29 S2 and/or M561 before G29, to clear any existing compensation, otherwise you’re doing a compensation on top of an existing compensation.
                                      A Former User 1 Reply Last reply Reply Quote 0
                                      • A Former User
                                        A Former User @droftarts last edited by
                                        @droftarts said in DWC not available while running mesh probe routine:
                                        is there really any point in debugging old code?
                                        tbh we don't actually know if the server crashed or is just busy
                                        • droftarts
                                          droftarts administrators @Guest last edited by
                                          @bearer there was an error in the posted M122, and now he’s explained a bit more about what he was doing, I’m inclined to think that there may not be sufficient error trapping to stop G29 commands using too many probe points, particularly if there’s a lot of messages about skipped ones. So probably not related to DWC. I’d expect the G29 code to still be the same in current firmware versions, so worth following up/trying to replicate.
                                          • A Former User
                                            was thinking about the 3.0 part, have been more than one change to z-probe stuff since then afaik (admittedly pending a new duet 3 I haven't been paying close attention), but its pretty standard to be debugging the latest code in any case.
                                            • gnydick
                                              Correlated it was an overflow due to too big of a message. I fixed my config so it won't miss any points and it works perfectly now.
