    LCD display temperature
    • paultje95
      paultje95 last edited by
      Hey everyone,
      I have a question. and I hope someone can help me, my duet lcd display shows -273 at the nozzle temperature if it is not on while the bed temperature is just 0.
        Please post your config.g. It sounds like you may be missing a G10 command to set the heater temps to 0. In RRF -273 is equivalent to off.
        For example, this is what I have in my tools section:
        ; ##	7 - TOOLS
        M563 P0 S"Titan Aero" D0 H1                             ; Define tool 0 (Titan Aero extruder)
        G10 P0 X0 Y0 Z0                                    	; Set tool 0 axis offsets
        G10 P0 R0 S0                                       	; Set initial tool 0 active and standby temperatures to 0C
        T0                                                 	; Select first tool
        • paultje95
          okay thanks.
          here my config.g.
          G21 ; Work in millimetres
          M111 S0 ; Debug off
          M665 L267 R135.260 B116 H291.300 X-0.880, Y -0.300, Z 0.000 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0.01 Y0.01 Z-0.01, tilt X0.00% Y0.00% ; Put your endstop adjustments here, or let auto calibration find them
          M550 P"Anycubic" ; Set machine name
          M552 S1 ; Turn network on
          M587 S"WiFi_UFLR" P"3542@WRMR!" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S1 ; drive 0 goes forwards
          M569 P1 S1 ; drive 1 goes forwards
          M569 P2 S1 ; drive 2 goes forwards
          M569 P3 S1 ; drive 3 goes forwards
          M569 P4 S1 ; drive 4 goes forwards
          M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
          M84 S30 ; Set idle timeout
          M92 X80.00 Y80.00 Z80.00 E96.00 ; Set steps per mm
          M201 X2000.00 Y2000.00 Z2000.00 E2.00 ; Set accelerations (mm/s^2)
          M203 X12000.00 Y12000.00 Z12000.00 E3000.00 ; Set maximum speeds (mm/min)
          M350 X256 Y256 Z256 E256 I1 ; Configure microstepping with interpolation
          M566 X300.00 Y300.00 Z300.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
          M906 X900.00 Y900.00 Z900.00 E700.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          G31 P100 X0 Y0 Z18.598 ; Set Z probe trigger value, offset and trigger height
          M557 R110 S25 ; Define mesh grid
          M558 P4 H1 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
          M143 H0 S100 ; Set temperature limit for heater 0 (Bed) to 100C
          M143 H1 S260 ; Set temperature limit for heater 1 (Nozzel) to 260C
          M305 P0 T97000 B4267 R4700 ; Set thermistor + ADC parameters for heater 0 (Bed)
          M305 P1 T100000 B4267 R4700 ; Set thermistor + ADC parameters for heater 1 (Nozzel)
          M307 H0 A157.4, C706.8, D0.6 V12.4 B0 S1 ; Use PID on Bed heater (may require further tuning)
          M307 H1 A415.2, C117.8, D5.5 V12.5 B0 S1 ; Use PID on Nozzel heater (may require further tuning)
          M106 P0 S0 I0 F250 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S0 I0 F250 H1 T50 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          G10 P0 R0 S0 ; Set tool 0 active and standby temperatures to 0C
          M563 P0 S"Nozzel" D0 F0 H1 ; Define tool 0, tool name, uses extruder drive 0, Fan 0, Heater 1
          M208 Z0 S1 ; Set minimum Z
          T0 ; select first hot end
          T1 ; Select first tool
          M501 ;Read parameters from override file
            dc42 administrators @paultje95 last edited by
            @paultje95 said in LCD display temperature:
            The G10 P0 command must come after the M563 P0 command.
            • paultje95
              @dc42 said in LCD display temperature:
              thanks it works
