Duet not extruding on x axis and panel due has no screen
Ok i did the test you asked and did the commands thru the gcode console and with tool 0 on drive 0 selected when i give the G1 E20 F5 command i get a slight twitch on the motor shaft but the shaft spins freely with little to no resistance on the shaft i switched the motor cable to the drive 1 and set my config_g to use tool 0 drive one and with tool 0 drive one selected given the G1 E20 F5 command the motor moves as it should 5mm per sec and extrude 20mm of filament i issued a M302 P1 command before each test of the motor i ran the M906 command on with the tool 0 drive 0 selected and this is what i got
6:00:27 PMM906
Motor current (mA) - X:800, Y:800, Z:800, E:800:800:800:800:800:800:800, idle factor 30% -
It sounds to me that you have a faulty E0 motor driver. Ask your supplier to replace the Duet under warranty.
