Solved code ???? o k then ???
So i think i get this now,, your gonna laugh,,, not ever having worked with this stuff can i assume everything after the ; is a "note" to the specific g or m code entry??.. everything before is the ; actual "Working code" notes to remind me what I've done in the future?? the notes are not attached to the software in any way???? so if i make a change the notes stay the same ?? so lets say, i want to get rid of stall.... lets say its set at S3 (example) all i would do is change the S1 and change the note to somthing like endstop sw. n/o so i remember in the future ??
Yes, everything after a ; is a comment that isn't used by the firmware.
so the only thing i need to change is M574 X1 Y1 Z1 S3.........to S1 in my homeall file like i did in config.g
@ziggymanpopo said in code ???? o k then ???:
M98 Pdeployprobe.g ; deploy mechanical Z probe
Yes, remove the M574 from the homeall, and the probedeploy and retract. And the M915 line.
what do i do with this ???
M915 X S2 Y S3 R3 F0 ; set X and Y sensitivity to 0, when stall home XY and resume print, filtered so it takes 4 steps to figure out it has stalled
do i delete this whole line ? home x & home y. files both have M915o k thats the best guess i have
the whole M574 line/ and only from home all
Delete those lines from all your homing files if you aren't using stall detection anymore.
sorry that was a question
great thank you ill give that all a try tonight
well that did the trick everthing is back in working order.
i really appreciate all your patients you guys rock
back to tweeeking thank you
