Duet Wifi - Ender 3 - Motor cable
  • Hi Everyone,
    Sorry if this problem was already posted but I didn't find any specific thread regarding this problem.
    The problem is as followed:
    I have an Ender 3 and installed the Duet 2 Wifi board. All my motors were installed (X, Y, Z, E0).
    I used 2 of the black Ender cables, and changed the connector that fits the board with the delivered connectors.
    I used 2 other cables (the colored ones) and also changed those connectors with the board connectors.
    I checked the polarity of all the cable which were the same and fine.
    On my first start up, the motors with the Black Ender 3 cables worked fine, all smooth.
    the motors with the other cables didn't move, and made a lot of noise.
    I checked the wiring, the motors, but that wasn't the problem.
    I switched the cables, and tried the black Ender 3 cables on the motors that made the noise.
    Now the motors did work just fine, and smooth.
    So I know that the problem is somehow with the cables. Polarity is fine, the only thing I thought was that the cables were maybe a bit to small. So I had the other 2 Ender 3 black cables lying around, I wanted a bit longer cables, so I cut off the cable in the middle, and soldered some wires, with a much larger diameter on them, to make them longer.
    I tested those cables, and again the same problem. The original, unmoddified cables work just fine, the other ones, even with a bigger diameter don't work.
    I've checked the resistance, I even dit send a High frequency signal on every cable, and checked the response on a oscilloscope. They are all fine.
    I don't know if anyone has this problem, if so does anyone have a solution?
    Regards,
    AlexDeb.
    Please check the phasing of the cable/motor combination. See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers and the following section of the same wiki page.
