    Layer synchronized time-lapse using a cell phone
    • mrehorstdmd
      mrehorstdmd last edited by
      I use an old cell phone running Open Camera to monitor prints. Open Camera has a built in intervalometer function. As the pictures are snapped at specified time intervals, Google Photos backs the images up to the web, as soon as they are snapped, where I can view them to check print progress. After the print is done, I can use the image sequence to make a conventional time lapse video.
      I have a new technique that snaps the pictures at each layer change, after the extruder has been moved away from the print. It uses a bluetooth camera shutter button to trigger the camera. All I do is mount the bluetooth button on the printer where the button will get bumped whenever I send the extruder to Y=150 using custom gcode that runs after every layer change.
      Here's a sample: layer synchronized time lapse on UMMD
      I need to tweak the extruder retract/unretract a bit to fix the blobbing that occurs at the start of new layers, but the trigger mechanism seems to be working reliably.
      More: https://drmrehorst.blogspot.com/2020/04/fancy-no-hack-layer-synchronized-time.html
      • Danal
        Danal last edited by
        Fantastic!
        This whole topic reminds me of the PERL motto: TIMTOWTDI (tim-tau-dee) (There Is More Than One Way To Do It).
