    Duet Wifi endstop showing N/A in active low
    • MrIvorVra
      MrIvorVra last edited by
      After upgrading the complete firmware to 3.01my Duet says that the endstops are not connected.
      Clicking the endstop manually lights up the light on the board and on the endstop.
      I changed nothing on the board after the upgrade.
      Setting the M574 to S1 shows the endstops as actually connected but then the signal is inverted
      • M119
      • Endstops - X: no endstop, Y: no endstop, Z: no endstop, Z probe: at min stop
        That's with M547 set to S1
      • Danal
        Danal last edited by
        What are the M950 definitions for these? And/or, just post your whole config.g, please.
        • MrIvorVra
          My apologies it's set to S0 not S1.
          config.g
          • Danal
            Danal last edited by Danal
            Just for reference, these are working for me on Duet3 hardware:
            ; Endstops and probes
            M574 X1 S1 P"io1.in"                      ; Set homing switch configuration X1 = low-end, S1 = active-high (NC)
            M574 Y1 S1 P"io2.in"                      ; Set homing switch configuration Y1 = low-end, S1 = active-high (NC)
            Yours look like this:
            M574 X1 S0 P"xstop"                                      ; configure active-low endstop for low end on X via pin xstop
            M574 Y1 S0 P"ystop"                                      ; configure active-low endstop for low end on Y via pin ystop
            Which is very similar. Two things might be making a difference:
            1. S0 v S1. I have physical switches that are "Normally Closed". This should be S1. Are yours normally closed or normally open?
            2. The pin definition. I take it you are a running on a Duet 2?
            If so, per this guide, everything looks correct.
            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
            In summary, I don't see anything wrong with your definitions except S0/S1, which you can try both ways, once you can see the switches status
            When you say "upgraded to 3.01", what RC? I highly recommend the very latest, that is DSF 2.1.2 and RC10. The traditional commands
            sudo apt update
            sudo apt upgrade
            Will get you there.
            • MrIvorVra
              S0 will give out
              • M119
              S1 will give
              • M119
              • Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: at min stop
              When you go to Machine-Specific if you set S0 it Says "n/a" in the triggered column
              the switches I use are normally closed that use a signal pin
              as for firmaware
              • RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC10 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-956GU-DJMSN-6J9F4-3SD6S-1VRHHUsed output buffers: 3 of 24 (10 max)
                With RRF 3.01 you must use S1. If the enstop inputs are active low, invert the pin. For example:
                M574 X1 S1 P"!io1.in"
                • MrIvorVra
                  Thank you.
                  This solved it.
