    Core XY multiple z-axis stall detection
    • Luar
      Luar last edited by
      Hello, everyone.
      I am trying to configure my Core XY printer.
      Configuration:
      Duet2 Wifi, Duex2, Firmware 3.01RC11, Four Z Steppers connected to "Drive 0, 1, 2, 3".
      End stop of the Z axes is at Z max (bottom). Attached my Config and a Z-Home macro.
      The problem is (when running the macro), the four Z-Steppers drive down the bed (+z), but when hitting the frame they don't turn off. The steppers rattle until I stop it manually.
      I have already tried different stall detection thresholds between +20 and -64.
      Can anyone help me with my problem?
      Many thanks in advance.
      Z-Home
      M400                    		; make sure everything has stopped before we make changes
      M915 P0:1:2:3 S-64 F0 R0 H400	; Configure motor stall detection
      M574 Z2 S4              		; configure sensorless endstop for high end on Z
      M913 Z20        				; reduce motor current to 20%
      G91                     		; use relative positioning
      G1 H1 Z700 F4000				; move Z 700mm down, stopping at the endstops
      G90                     		; back to absolute positioning
      M400                    		; make sure everything has stopped before we reset the motor current
      M913 Z100     					; motor currents back to normal
      Config
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"CoreXY"                                 ; set printer name
      M667 S1                                        ; select CoreXY mode
      M569 P5 S1                                     ; physical drive 5 goes forwards
      M569 P6 S1                                     ; physical drive 6 goes forwards
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S1                                     ; physical drive 3 goes forwards
      M569 P4 S1                                     ; physical drive 4 goes forwards
      M584 X5 Y6 Z0:1:2:3 E4                         													; set drive mapping Z = front left, front right, rear left, rear right
      M671 X-166.4:166.4:-166.4:166.4 Y-172.525:-172.525:172.525:172.525			; leadscrews at front left, front right, rear left, rear right
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z400.00 E873.08            ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1300 E1700 I30               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X-157.6 Y-162.5 Z0 S1                     ; set axis minima
      M208 X157.6 Y162.5 Z295 S0                     ; set axis maxima
      M574 X1 S3                                     ; configure sensorless endstop for low end on X
      M574 Y1 S3                                     ; configure sensorless endstop for low end on Y
      M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
      M557 X-150:150 Y-150:150 S20                   ; define mesh grid
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M308 S1 P"spi.cs1" Y"rtdmax31865"              ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"duex.e2heat" T1                      ; create nozzle heater output on duex.e2heat and map it to sensor 1
      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"duex.fan3" Q500                      ; create fan 0 on pin duex.fan3 and set its frequency
      M106 P0 C"Pump" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"duex.fan4" Q500                      ; create fan 1 on pin duex.fan4 and set its frequency
      M106 P1 C"120mm Fan" S1 H1 T45                 ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"duex.fan5" Q500                      ; create fan 2 on pin duex.fan5 and set its frequency
      M106 P2 C"Part Cooling" S1 H-1                 ; set fan 2 name and value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F2                     ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
        Have you checked that your Z homing move is above the minimim speed for stall detection?
          https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Minimum_recommended_speed_for_stall_detection
          See the calculation there to determine your H value.
