    Wifi not working on duetwifi
    • steinruneundefined
      steinrune
      I have some problems with my duet2wifi.
      For some time now the wifi has been unreliable when i turn on the printer. It would connect most times, but about 1 in 10 times it dont, and i had to restart it or connect it to a pc to manually get it to connect.
      The printer worked fine yesterday, but today it woldent connect even what i tried. I`ve spent most of the day trying firmware updates, and installing evertything from scratch.
      It seems like i cant get the wifi module to idle, or even to update the fimware.
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
      ok
      m997 s1
      Trying to connect at 230400 baud: failed
      Trying to connect at 115200 baud: failed
      Trying to connect at 74880 baud: failed
      Trying to connect at 9600 baud: failed
      Error: Installation failed due to comm write error
      ok
      m552 S0
      ok
      m552
      WiFi module is being started
      ok
      m587
      M587: Failed to retrieve network list
      ok
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6JTD8-3SJ6N-TZ84G
      Used output buffers: 1 of 24 (1 max)
      Static ram: 25712
      Dynamic ram: 93200 of which 356 recycled
      Exception stack ram used: 256
      Never used ram: 11548
      Tasks: NETWORK(ready,1884) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:17:00 ago, cause: power up
      Last software reset at 2020-05-05 21:56, reason: User, spinning module GCodes, available RAM 5956 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 26.2, current 30.1, max 30.2
      Supply voltage: min 0.1, current 0.5, max 0.8, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 1631780863
      Slowest loop: 0.18ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "m122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.18ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is starting
        WiFi module is disabled
        ok
      Any suggestions what the problem could be?
      • A Former User?
        A Former User @steinrune
        @steinrune said in Wifi not working on duetwifi:
        sounds like a bad wifi module.
        even if you can't update it it should still run its current firmware, which it doesn't seem to be doing.
        long shot but could try starting the Duet without the SD card, wait, insert SD card and run M21 M552 S-1 M552 S0 M997 S1 over serial after it has started to try flashing it without being affected by any config on the card.
        There is also the possibility to enable some debug info using M111 P14 S1 but doubt you'll get any adittional info from that given the current state.
          steinrune
          Thanks for the suggestion, but sadly it didn’t make any difference.
          The WiFi module is a ESP-12S.
          I have a ESP-12F on a Wemos D1 just lying around. Could I just pop that in without any issues with the software?
          • A Former User?
            absolutely-ish. run M997 S1 after the procedure to flash the new module, is only the 12S and 07S that is used by Duet3d but it has to do with certifications - on your own you can use any ESP with the same footprint and the 12F just has a few extra pins on the end.
              steinrune
              It worked!
              Thanks for the help 🙂
              • A Former User?
                A Former User
                Bare hyggelig!
