    G28 Error Homing failed
    • Dr_Taragon
      Dr_Taragon last edited by
      Had issues with printer not moving.
      Updated firmawar to 3.0
      Now this: Can't home.
      Firmware Version: 3.0 (2020-01-03b3)
      WiFi Server Version: 1.23
      Web Interface Version: 1.22.6
      Config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 09 2020 17:24:43 GMT-0400 (heure d’été de l’Est)
      M550 P"He3D_K280" ; set printer name
      M665 R181.9354 L344 B140 H615 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M551 P"" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 Z1 S1 P"null" ; configure active-high endstop for low end on Z via pin null
      ;M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      ;M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      ;G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      ;M557 R85 S20 ; define mesh grid
      ; homedelta.g
           ; move X+Y to the centre
      ;G91 ; relative positioning
      ;*** Slow homing has been configured. Change F360 to F3600 below when your configuration is working
      ;G1 H1 X625 Y625 Z625 F360 ; move all towers to the high end stopping at the endstops (first pass)
      ;G1 H2 X-5 Y-5 Z-5 F3600 ; go down a few mm
      ;G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      ;G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      ;G90 ; absolute positioning
      ;G1 X0 Y0 F6000
      So what's going on
        Phaedrux Moderator @Dr_Taragon last edited by
        @Dr_Taragon said in G28 Error Homing failed:
        This probably has something to do with it. Try replacing null with zstop
