    PanelDue 4.3" never connects
    PanelDue
    343
    • Chrissundefined
      Chriss
      Hi *,
      My PanelDue 4.3" do not connect to my Duet2 anymore. Both have the most recent FW running (1.24/3.01-RC12). The connection worked till some hours ago with the same firmware. I played with the BLTouch config only.
      The PanelDue is connected via the 4 wire cable. I replaced it with a other one. I tried the ribbon cable which came with the Panel. I used a 7" PanelDue via the 4 wire cable. I tested with both cables in parallel. All with the same result, the display stays at "Connecting"
      I learned from a other thread that "M575" is important here.
      After reboot:
      11/05/2020, 00:57:42	M575 P1
      Channel 1: baud rate 57600, requires checksum
      11/05/2020, 00:57:37	M575 P0
      Channel 0: baud rate 115200, does not require checksum
      The display is at 57600, so I changed it:
      11/05/2020, 00:59:08	M575 P1
      11/05/2020, 00:58:54	M575 P0 B57600 S1
      Nothing helped.
      I'm a bit lost now. Any ideas?
      Cheers, Chriss
      • A Former User?
        A Former User @Chriss
        @Chriss said in PanelDue 4.3" never connects:
        M575 P1 B57600 S1 is the config you want, P0 is for the USB conside console afaik.
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @A Former User
          @bearer said in PanelDue 4.3" never connects:
          M575 P1 B57600 S1 is the config you want, P0 is for the USB conside afaik.
          And that is what I have, the "P0" was just to be on the save site for testing.
          Any other idea?
          Cheers, Chriss
          • A Former User?
            Any other idea?
            IIRC having two identical M575 commands was just a work around for non-standard baud rates and fixed in RC12, but you could try it.
            Maybe post the complete config, maybe someone spots any changes the BL touch stuff could have done to IO_0?
            Btw, you only need the 4 pin wire to get past "connecting", the ribbon is just for the SD card.
            • Chrissundefined
              @bearer
              That with the cable is clear, I just wanted to mention what I tried already.
              I created a new configuration from scratch with the configtool to make sure that I did not messed up the configuration during my BLTouch journey (I used the "Creality Ender 3 Pro".) Still with the same problem.
              config.g
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue May 12 2020 16:59:30 GMT+0200 (Central European Summer Time)
              G90                                            ; send absolute coordinates...
              M83                                            ; ...but relative extruder moves
              M550 P"Ender 3 Pro"                            ; set printer name
              M918 P1 E4 F2000000                            ; configure direct-connect display
              M552 S1                                        ; enable network
              M586 P0 S1                                     ; enable HTTP
              M586 P1 S0                                     ; disable FTP
              M586 P2 S0                                     ; disable Telnet
              M569 P0 S0                                     ; physical drive 0 goes backwards
              M569 P1 S0                                     ; physical drive 1 goes backwards
              M569 P2 S1                                     ; physical drive 2 goes forwards
              M569 P3 S0                                     ; physical drive 3 goes backwards
              M584 X0 Y1 Z2 E3                               ; set drive mapping
              M350 Z128 I0                                   ; configure microstepping without interpolation
              M350 X16 Y16 E16 I1                            ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00 E93.00               ; set steps per mm
              M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
              M203 X9000.00 Y9000.00 Z180.00 E6000.00        ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                        ; Set idle timeout
              M208 X0 Y0 Z0 S1                               ; set axis minima
              M208 X310 Y310 Z400 S0                         ; set axis maxima
              M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
              M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
              M950 S0 C"duex.e5heat"                         ; create servo pin 0 for BLTouch
              M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000  ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y0 Z2.5                            ; set Z probe trigger value, offset and trigger height
              M557 X15:215 Y15:195 S20                       ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
              M143 H0 S150                                   ; set temperature limit for heater 0 to 150C
              M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                        ; map heated bed to heater 0
              M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
              M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
              M143 H1 S275                                   ; set temperature limit for heater 1 to 275C
              M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
              M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
              M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H1:0 T45                            ; set fan 2 value. Thermostatic control is turned on
              M563 P0 D0 H1 F0                               ; define tool 0
              G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
              G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
              Do you need more?
              Cheers, Chriss
                jay_s_uk
                @Chriss
                Where's the
                M575 P1 B57600 S1
                in that config?
                • Chrissundefined
                  Chriss @jay_s_uk
                  @jay_s_uk
                  Not there, but it seams like it is the default. It is set to the expected parameters when I query "M575 P1". But I will try to add it tomorrow.
                  A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                  • A Former User?
                    @jay_s_uk
                    Not after RC12
                    • Chrissundefined
                      @bearer
                      Fiddlesticks!
                      From the RC12 WHATS_NEW_RRF3.md:
                      All PanelDue users: the PanelDue connector (or IO_0 on Duet 3) is no longer dedicated to PanelDue, therefore if you connect a PanelDue to this port you must use the following command in config.g to enable it: M575 P1 S1 B57600. You can use baud rates other than 57600, however the IAP files all assume 57600 baud; therefore if you use another baud rate then PanelDue will not display firmware update progress.
                      😞 To many things in parallel.....
                      I like the new behavior in "3.01":
                      If the serial aux port hasn't been enabled, M575 P1 with no other parameters now reports this
                      It works now with the fresh generated config and I added "M575 P1 B57600 S1" to the config. I guess that the configtool should ask for a PanelDue and add this parameter than.
                      I will check my "actual" config now, it is proven that it must be a configuration problem.
                      Cheers, Chriss
                      • A Former User?
                        Very good point!
                          dc42 administrators @Chriss
                          @jay_s_uk
                          In 3.01-RC12 the M575 P1 command fails to tell you that the port is not enabled. The fix for that will be in the 3.01 release.
