System reset during print - RRF3.1.0
  • I know RRF3.1.1 is out but I wanted to give this report incase this isn't one of the reported bugs.
    I was 99% through a print and had a reset. Fortunately my print is fine and I can live without the last 1%.
    Here is an M122 report
    m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet Ethernet 1.02 or later
    Board ID: 08DGM-9T6BU-FG3S4-6JTDL-3SD6Q-9SRMF
    Used output buffers: 1 of 24 (11 max)
    Static ram: 28180
    Dynamic ram: 92348 of which 64 recycled
    Exception stack ram used: 248
    Never used ram: 10232
    Tasks: NETWORK(ready,136) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:00:10 ago, cause: software
    Last software reset at 2020-05-19 17:35, reason: Stack overflow, spinning module none, available RAM 9836 bytes (slot 0)
    Software reset code 0x4111 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f80e BFAR 0xe000ed38 SP 0x2001ffb4 Task NETW
    Stack: 20002860 20002894 00455625 00000000 00000000 200029b8 20002a54 0000000a 00454c35 200028c4 200055f4
    Error status: 0
    MCU temperature: min 37.4, current 37.7, max 38.1
    Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
    Cache data hit count 16561366
    Slowest loop: 2.42ms; fastest: 0.13ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 0.6ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 8.19ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    Interface state active, link 100Mbps full duplex
    I can provide other information if required.
    @jay_s_uk said in System reset during print - RRF3.1.0:
    Task
    Thanks for the report, but I am almost 100% sure this problem has been fixed in RRF 3.1.1.
  • @chrishamm
    Thanks for the quick answer. I shall be on my merry way...
    Yes, that problem is the reason why I wanted to release RRF 3.1.1 so soon after 3.1.0. You can find the history at https://forum.duet3d.com/topic/16390/3-1-0-firmware-reboots-periodically/31. I've never been able to reproduce it, but the M122 report made it clear what the problem was.
