Connecting my 7 inch Paneldue to my Duet3
  • My Paneldue came with a 2X5 ribbon cable connector and a 4 wire cable wired straight thru. The wiring diagram I've seen for this cable show a 5 pin connector on one end and 4 on the other and the middle two wires reversed. I've gotten as far as updating the firmware on the Duet3 and I'm running it with a Raspberry Pi 4. Is there documentation on the PanelDue? Would someone supply a link or even guidance on how to hook it up. The ribbon cable doesn't seem to have an appropriate connector on the Duet3. There is a 2x5 connector but it is not identified on the Duet3 Wiring diagram. Thank you. I have an old (2003) Shopbot CNC gantry (48"X98") machine. And it's overdue for an update. The Duet3 is more than enough to run that machine. I'm excited to hear what it will sound like with modern stepper drivers. There's only 4 steppers and no limit switches (but I have some on order). Again, thanks for the help.
  • Wow that was fast! Thanks for the link.
