DueUI on Maestro
  • Hi guys, I'm trying to get DueUI running on my Maestro, without success so far.
    I uploaded the 3.02 DSF release to the system files on my Maestro, but the webpage always returns an error that is can't retrieve the configuration file. I
  • @CCS86 You probably want the Standalone zip instead of the DSF release unless you are actually running a web server on another computer. Make sure you have Standalone set on the settings page and make sure the URL in "DueUI config file URL" is correct. You can put that URL in any web browser to test. You should also use the DuetWebControl to make sure there's a dueui_config.json file in the /sys directory of the Maestro.
    Which version of RRF are you running, 2 or 3?
  • @gtj0 said in DueUI on Maestro:
    I'll give that a try, thanks!
    I'm on RRF3
