Heater problem
Hi all,
Heater 1 fault: heater monitor 0 was triggered is the error I get. I don't know what causes this.
Already erased the whole mainboard and updated the firmware. But still the same problem. As soon as the desired temperature has been reached the error pops up.Anyone knows how to solve this ?
Can you post your config.g and tell us what firmware you're using?
What is the heater and sensor?
What gcode are you using to trigger the error?Have you seen this document?
https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them
Problem is solved after a pid tuning. Hopefully it doesn't come back
