Duet Wifi was working, but now won't connect to wifi
  • As the title says, I had this board setup and working great on firmware 3.0 and 3.1, but I updated to 3.1.1 and the printer sat for a bit waiting for a new fan, but when I went to test the new fan, the status lights were on but no wifi connection. Is my wifi module bad? If so is it possible to replace the module via soldering since my board is drastically out of warranty?
    What I've tried:
    The erase button and installing fresh 3.1.1 with freshly generated config.
    Erase and install 3.0.0
    Configuring wifi by gcode
    Checking it wasn't acting like it's own access point
    I can connect by USB, but what I get for the following commands:
    M115:
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELE
    CTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2020-01-03b3
    M552:
    WiFi module is being started (never running, always started)
    M587
    Error: Failed to retrieve network list (With WIFI both on/off)
    M587 S"SSID" P"password"
    Error: Failed to add SSID to remembered list
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.0 or
    1.01
    Board ID: 08DAM-999TL-MQ4S4-6J9F6-3S46L-TNHVY
    Used output buffers: 3 of 24 (13 max)
    Static ram: 30516
    Dynamic ram: 91208 of which 12 recycled
    Exception stack ram used: 320
    Never used ram: 9016
    Tasks: NETWORK(ready,1888) HEAT(blocked,1240) MAIN(running,3736) IDLE(ready,156)
    Owned mutexes:
    Last reset 00:39:16 ago, cause: power up
    Last software reset time unknown, reason: Hard fault, spinning module GCodes, av
    ailable RAM 9152 bytes (slot 2)
    Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0041f003 BFAR
    0xe000ed38 SP 0x2001ff74 Task 0x5754454e
    Stack: 0044b753 0047bb90 6000000f 00000000 20003d50 e000ed04 00026d36 a5a5a5a5 0
    0451eaf 00000000 00000000 e000ed04 00455efd a5a5a5a5 200055dc a5a5a5a5 10000000
    e000ed04 20003d50 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
    Error status: 0
    Free file entries: 10
    MCU temperature: min 33.0, current 33.3, max 33.5
    Supply voltage: min 12.3, current 12.4, max 12.4, under voltage events: 0, over
    voltage events: 0, power good: yes
    Cache data hit count 3080553735
    Slowest loop: 0.22ms; fastest: 0.11ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets
    0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0
    , 0
    === AuxDDARing ===
    , 0
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "m122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 0.22ms; fastest: 0.01ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is starting
      WiFi module is disabled
  • Moderator
    Can you try reinstalling the wifi server firmware 1.23?
    Also try to update to 3.1.1 again.
  • @Phaedrux That fixed it! I didn't expect it to, since I thought the newest firmware files simply bundled both the main firmware and wifi firmware, but I am happy to report I was wrong.
    Thank you so much. I was dreading trying to figure out how to fix the board if the wifi was bad.
