Monoprice Mini Delta on Duet2Wifi Calibration Problem
i update my Monoprice Mini Delta with a Duet2Wifi Board.
First i struggle a bit with the IR Top Endstops. Now i repaced them with Hadware Switches, which runs well.
At bottom i connect all 3 z-Endstops(switchs) and put it as Z-Probe. So far so good. I finaly stuck now at Calibration.
I think i got a wrong high anywhere. I dont find. May sombody find it in 1 sec:). If ill do a G32 i get thees output:31.5.2020, 16:11:49 G32
Error: Z probe was not triggered during probing move
31.5.2020, 16:11:52 Error: Z probe was not triggered during probing move
31.5.2020, 16:11:55 Error: Z probe was not triggered during probing move
31.5.2020, 16:11:55 Error: Compensation or calibration cancelled due to probing errorsthe G28 seems flat but on the wrong high.:
Hers my Bed.G:
; bed.g
; called to perform automatic delta calibration via G32
; generated by RepRapFirmware Configuration Tool v3.1.1 on Wed May 27 2020 20:07:18 GMT+0200 (Mitteleuropäische Sommerzeit)
; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
G30 P0 X0 Y50 H0 Z-99999
G30 P1 X50 Y-42.45 H0 Z-99999
G30 P2 X-50 Y-42.45 H0 Z-99999
G30 P3 X0 Y42.4 H0 Z-99999
G30 P4 X36.72 Y-21.2 H0 Z-99999
G30 P5 X-36.72 Y-21.2 H0 Z-99999
G30 P6 X0 Y0 H0 Z-99999 S6
; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)And my Config.g
; Communication and general
M111 S0 ; Debug off
M83 ; ...but relative extruder movesM665 R62 L121 B50 H124.12 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
xx ; Machine name and Netbios name (can be anything you like)
xx ; Machine password (used for FTP);*** End of factory test lines to be removed
M552 P192.168.178.48 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet;*** Networking
M552 S1 ; Turn network on;M555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
M83 ; ...but relative extruder moves; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M92 X100.00 Y100.00 Z100.00 E101.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; set active low and disabled endstops
; Thermistors
M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correctionM570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
M558 P5 H5 I1 F360 T4000 ; set Z probe type to switch and the dive height + speeds
G31 p0001 X0 Y0 Z6 ; set Z probe trigger value, offset and trigger height
M557 R52 S20 ; define mesh grid; Heaters
;M305 P0 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 1
M143 H0 S120 ; set temperature limit for heater 1 to 120C
;M305 P1 T100000 B4092 R2200 ; set thermistor + ADC parameters for heater 2
M143 H1 S280 ; set temperature limit for heater 2 to 280C; Fans
M106 P2 S0 I0 F255 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F255 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 F0 H1 ; define tool 1
G10 P0 X0 Y0 Z0.28 ; set tool 1 axis offsets
G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
;*** If you have a single-nozzle build, comment the next 2 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures; Custom settings are not defined
Hmm the fotoupload doesn't work so here are the params of Height Map:
Number of points: 21 Probing radius: 52 mm Probe area: 84.9 cm² Maximum deviations: -6.839 / -5.051 mm Mean error: -5.894 mm RMS error: 0.549 mm
@tobias-koch-tk said in Monoprice Mini Delta on Duet2Wifi Calibration Problem:
G31 p0001 X0 Y0 Z6 ; set Z probe trigger value, offset and trigger heightWhat type of probe is it? G31 P0001 is nonsense. P1000 more likely.
They are 3 Switches under the buildsurface. I put them in row and connect them to z-probe. They trigger 1000 if hit and 0 if not hit. Ill try with P1000
Same Problem
31.5.2020, 23:05:46 G32
31.5.2020, 23:05:49 Error: Z probe was not triggered during probing move
31.5.2020, 23:05:53 Error: Z probe was not triggered during probing move
G29 says:
G29
Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
49 points probed, min error -5.911, max error -3.354, mean -4.845, deviation 0.643
Height map saved to file heightmap.csv
G31 p0001 X0 Y0 Z6
Ok, next question. How did you get Z6? If the probe is switches under the bed that gets pushed down by the nozzle contacting, how is the nozzle 6mm away when it triggers?
If it's a contact probe the trigger height is likely slightly negative.
Have you used this?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
Okay that realy helps. I thought its the hight between the trigger steps. I run the Prozess and came out at -0.003mm. And edit to config.g After reboot i get the G32 done : G32
Calibrated 6 factors using 7 points, deviation before 2.820 after 0.080
and G29:
G29
49 points probed, min error -0.535, max error 0.205, mean -0.061, deviation 0.182
Height map saved to file heightmap.csvThe Height Map dont look that good but much better as before.
Switches under the bed have a disadvantage of the bed being flexible and the whole mechanical setup being compliant in different amounts at different points on the bed. Really not suitable for generating a detailed heightmap in my opinion, though it would be fine for measuring a single point at the center to define the Z0 point. To do a heightmap ideally you'd have a smart effector or some probe type that doesn't need to physically press into the bed so much.
