Duet2Wifi driver 0 gets very hot
Duet 2 wifi v1.04c
Duet Web Control 3.1.1
Printer: BLV Cube CoreXYNew board, after connecting to 24V I found that the x-axis motor refuses to work and the driver gets very hot, Note that the driver heats up even when the motor is not connected at all.
I switched to driver E1(4) and everything works fine but still driver X(0) heats up.
I also crossed motors X/Y but the problem remains with driver X(0)
firmware updated didn't help.Is there a chance to save the board?
What should I do next?Here is my config
@Harel-Az said in Duet2Wifi driver 0 gets very hot:
you can do
M569 P0 S0 R-1
to disable the driver, but I suspect it will keep getting hot until it lets the smoke out in the end.(to save the board you could replace the chip)
How old is the board?
@Phaedrux new board, first use
If this is a genuine Duet purchased from an authorized reseller within the past 6 months, please contact them and initiate a warranty replacement. You can refer them to this forum thread. Sorry for the inconvience.
