Expansion Connector type CAN on Duet3D-Electronics
Hi all,
I'm a little confused right now.
So far I knew that the connection for the expansion cable on the Duet 3 and the Expansion 3HC is a normal Ethernet (RJ45).
I was just about to install both in a new printer, but I found that an RJ45 connector did not fit. !Which connector type is the right one?
Thank you!
Regards Christian (CR-3D)
RJ12 and RJ11, 6pin and 4 pin respectively will fit.
@CR3D its normally possible to pick up a "ADSL" or similar twisted pair RJ11 cable easily from many different places. I say normally - depending on your location right now you may need to get one online.
Edited to say the "ADSL" type is preferred because the pairs are twisted unlike a traditional RJ11 phone cable.
To be precise, a "High speed ADSL" (the ordinary ones are not twisted pair) or a VDSL cable. Although for short cable lengths in small systems, the type of cable is not critical.
@T3P3Tony
Do you know which cabled needs to be crossed? I crossed the two in the middle. But this is was more by accident.I saw something in the docu about 1 and 4MBit/s and more need to be crossed than. But I missed a pin layout.
(Sorry for buccaneering this thread.)
Using production Duet 3 boards, none of them should be crossed. Only the 2 pins in the middle are used. So connect pin 3 to pin 3, and pin 4 to pin 4.
Thank you very much. I guess that would be a more than helpful information on the wiring page.
Ok thanks for the quick answers!
I summarize:
You can use RJ11 or RJ12 cables.
You don't need crossover cables and you don't have to cross anythingRight?
@CR3D
Nope, the two middle pins must be crossed. That should be the case in usual DSL model cables.
@Chriss said in Expansion Connector type CAN on Duet3D-Electronics:
@CR3D
Nope, the two middle pins must be crossed. That should be the case in usual DSL model cables.think you've got your wires crossed here. DSL cables are twisted not crossed; OP needs a cable that connects 3 to 3 and 4 to 4 on either end, ideally but not neccecarily with the pair being twisted.
A crossed over cable would connect 3 to 4 and 4 to 3, irrespectively of it being twisted.
@CR3D said in Expansion Connector type CAN on Duet3D-Electronics:
I summarize:
yes.
