    Parts fan issue.
    • Deepnoizerundefined
      Deepnoizer
      Part Fan issue.
      Duet Wifi ... I had very hard time using Fan 0, where I suspect there might be hardware problem ... regardless.
      Decided to use 1 and 2 where FAN01 is extruder cooling and FAN02 I have parts fan connected.
      FAN01 appears to be doing well kicking in when thermostat kicks in but FAN02 appears to have mind of its own.
      I can't stop it (perhaps not sure how), but I set in slicer 0 fan for PETG and the thing still spins at 100%.
      What am I doing wrong here plz?
      Please see attached my fans section:
      M950 F0 C"fan2" Q500                               ; create fan 0 on pin fan2 and set its frequency
      M106 P0 S0 H1 T45                                  ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      Thx !
        Deepnoizer
        Just to add, tool fan in GUI is showing 0 and its still spinning.
          Did you change your tool definition to use the new fan?
            Deepnoizer
            I have not.
            So the F0 needs to change to F1
            deckingmanundefined 1 Reply Last reply Reply Quote 1
            • deckingmanundefined
              deckingman @Deepnoizer
              @Deepnoizer Not if fan 1 is the thermostatic hot end fan. If you want to use fan 2 for part cooling use F2 in your tool definition. If you want to use both fan 0 and fan 2 for part cooling use F0:2
                Deepnoizer
                I got it sorted thank you.
