    Extruder hit the model after print job is done
    436
    • yolkgk1undefined
      yolkgk1
      I'm using Duet 2 wifi, everything work perfect but only one problem. When print job is done, extrucder right away go down and hit the model, broken it! I think it must home all X Y Z axis but it alway go down and hit the model? Anybody have same problem and can help me fix this! many thank!
      • OwenDundefined
        OwenD
        At a minimum you'll need to post your slicer start and end gcode and your start.g and stop.g contents if they exist.
        yolkgk1undefined 1 Reply Last reply Reply Quote 0
        • yolkgk1undefined
          yolkgk1 @OwenD
          @OwenD I'm using Cura! I don't know where are start.g and stop.g? can you show me where they are!? many thank
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @yolkgk1
            @yolkgk1 If the exist, they will be in the SYS directory of your Duet.
            If you don't know about them, chances are they aren't the issue, so post your Cura start and end G code.
            • yolkgk1undefined
              yolkgk1 @OwenD
              @OwenD I don't add start and end G code in cura, I think it must auto home all axis and avoid hit the model? is it right?
              • OwenDundefined
                OwenD
                It won't do anything not commanded.
                It's not normal to home after a print.
                You need to post the files listed above and perhaps the gcode you are printing.
                yolkgk1undefined 2 Replies Last reply Reply Quote 0
                • yolkgk1undefined
                  yolkgk1 @OwenD
                  @OwenD said in Extruder hit the model after print job is done:
                  ok! I''ll show you the end of file!
                  • yolkgk1undefined
                    yolkgk1 @yolkgk1
                    This post is deleted!
                    • yolkgk1undefined
                      yolkgk1 @OwenD
                      @OwenD M121
                      M107
                      M104 S0 ;extruder heater off
                      M140 S0 ;heated bed heater off (if you have it)
                      G91 ;relative positioning
                      G1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure
                      G1 Z+0.5 E-5 F{travel_speed} ;move Z up a bit and retract filament even more
                      G28 X0 Y0 ;move X/Y to min endstops so the head is out of the way
                      M84 ;steppers offngontan
                      G90
                      this end G code work fine with Arduino mega 2560 and ramp 1.6! but with duet it not working! it only hit the model!
                      • OwenDundefined
                        OwenD
                        Remove G28 X0 Y0
                        Replace with G1 X0 Y0
                        • yolkgk1undefined
                          yolkgk1 @OwenD
                          @OwenD thank you! I'll try and tell you the result!
                            G90 ; absolute positioning
                            G1 X0 Y0 ; move to x0 y0
                            Include G90 to be sure you are in absolute movement first.
                            • yolkgk1undefined
                              yolkgk1 @Phaedrux
                              @Phaedrux So I need to change "G90 ; absolute positioning G1 X0 Y0 ; move to x0 y0" in my end G code?
                                What type of printer is it: Cartesian, delta, or something else?
                                • yolkgk1undefined
                                  yolkgk1 @dc42
                                  @dc42 it is Cartesian type!
                                    OK, I asked because on some deltas the M84 command on your slicer end Gcode will cause the hot end to drop into the print.
                                    Your end Gcode looks ok to me, assuming that your homing files are correctly set up so that G28 X0 Y0 homes just X and Y.
                                      Phaedrux Moderator @yolkgk1
                                      @yolkgk1 said in Extruder hit the model after print job is done:
                                      Well you need to be in absolute positioning mode to move to x0 y0. If you'r ein relative positioning mode (G91) X0 Y0 is a movement of nothing.
