3.0 to 3.1.1 bed crash
Not sure what happened, but after upgrading with the same settings, my Z movement doubled. Any ideas?
need more info
what else can I tell you? it's the same config file. only thing that changed was the firmware. I had to halve my steps/mm on Z. at my first print, the nozzle dug a 1 mm deep trough in my brand new build surface :(.
@gnydick said in 3.0 to 3.1.1 bed crash:
would that be the emperors new config or do you expect everyone to be up to date on your config?
Maybe if you were to (reluctantly) add the config you'd get some helpfull responses?
Nobody else has reported that problem. Did you run M98 P"config.g" after upgrading? If you do that, are there any error messages? Does M122 show anything unusual?
Perhaps an unintended change in the Z microstep setting?
I wish that was the case.
@deckingman I got no errors, it's the same config. I have both files and compared them.
