    Powering Pi+Duet3 6hc ?
    • duttiundefined
      dutti
      hey,
      I´m a bit confused about powering the Pi. I´m about to power the Pi from the Duet, but I´ve read I need something like a bypass on the Duet.
      Is this right?
      I really won´t damage the board.
      thnaks
      A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User @dutti
        @barbarossa-cologne said in Powering Pi+Duet3 6hc ?:
        thats the default setup, only need to connect the ribbon cable.
        (ref https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram#Section_Important_notes if you want to change this later)
        ((ooh, they've updated the link T3P3Tony posted below, much clearer now, stick to that one))
        • T3P3Tonyundefined
          T3P3Tony administrators @dutti
          @barbarossa-cologne If your Pi(including any peripherals like a screen and camera take <3A then you can power it from the Duet.
          See here:
          https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_Power_distribution
          In this case you will have the Int 5V En jumper and the 5V -> SBC jumper fitted.
          www.duet3d.com
