BL-Touch - multiple problems -
Hey,
My first start with the new Duet is a bit problematic. The BL-Touch isn't retract or deploying by itself.
While the BL doing its self test, it has retracted and deployed normally. But this was the only time the BL was moving by itself.
Push the BL stick in is working.
Errors:
G30 - error: Z probe already triggered at start of probing move.
Or G29
Error: Z probe already triggered before probing move started.
Sry
Just saw the guide for posting problems. I'll describe it better in future.
Thanks to all -
We will need to know more info.
What Duet board?
What firmware?
How is the BLTouch wired?
Post your config.g, deploy retract macros, homing files.Then we can get an idea on what's happening.
@Phaedrux @Phaedrux
Of course!! First of all I have to say thank you for the good support in this forum. It is very goood!!! thanks-Duet3 6hc + expansion (not connected yet, could be in seconds)
-Board: Duet 3 MB6HC (MB6HC)
DSF Version: 3.1.1
Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC9 (2020-04-21b1)
Wiring:
BL ---------Duet
White - io7.in
Black - GND
Yellow - io7.out
Red - 5vcodes:
config.g---------------------------; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"Duet 3" ; set printer name; Drives
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M569 P1.1 S1 ; physical drive 1.1 goes forwards
M569 P1.2 S1 ; physical drive 1.2 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z3600.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X800 Y800 Z800 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io7.in" H15 F120 1400 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:650 Y15:650 S30 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M307 H0 B0 S0.10 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on powerdeploy----------------------------
; deployprobe.g
; called to deploy a physical Z probe
M280 P0 S10 ; deploy BLTouchretract.g--------------------------------
; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouchhomez.g-------------------------
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit)
G91 ; relative positioning
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bedBL- Touch does the selfest. Its retracting and deploying when starting power.
thanks a lot,
the support here is very good. I started in februar with 3d Printing. If I dont understand something direct: I´m Sorry -
sos
I think @Phaedrux lives in a different time zone and I don´t wanna stress anybody.
Can anybody else help me?
thanks -
@barbarossa-cologne said in BL-Touch - multiple problems -:
To begin with, update your firmware to 3.1.1
Does your BLTouch respond if you send M401 and M402 to deploy and retract the pin?
Does it respond if you send it the command to enter test mode?
M280 P0 S120
What version of BLTouch is this?
@Phaedrux
short describtion for update firmware?
with pi 4M401 / M402 are not working. The web control shows the normal green button on rigth bottom screen but no moving.
When I connect the BL the test move happens.......M280 P0 S120
- green button on screen, no moving or something else.
I don´t know which version. Can I see it on the wire colours?
Original from antlabs and bougth last week.
thanks to canada -
This post is deleted! -
M280 P0 S120green button on screen, no moving or something else.
It sounds like a wiring issue. The probe is getting power and ground, but no signal. Triple check your wiring and crimps. A good test is to connect the short leads from the BLtouch directly to the board to eliminate the extension wires.
@barbarossa-cologne
I saw this settings made in the configuration tool. I tried to change the settings manual. Maybe I made somethig wrong there?
That all looks ok as long as you're actually wired up to the io7 in and out pins.
@Phaedrux
ok. I´ll check everything- -
@Phaedrux
What do you mean with ´´actually wired up to the ioin and out pins´´? -
I mean that your config looks ok, now the wiring must be correct for the config to work.
@Phaedrux
ok sry.
I tested the wiring. Its not the problem....
this is the last problem I have to solve before starting. Thats really bad. -
If that's the case and the wiring is good please update your firmware (as linked above for the Duet + SBC). Send M115 after to verify.
Then please send M98 Pconfig.g and report any errors.
@Phaedrux
M98 Error: Non-empty string expected
firmware is updated -
That's a weird error. You're sending this exactly?
M98 Pconfig.g
try M98 P"config.g"
@Phaedrux said in BL-Touch - multiple problems -:
M98 Pconfig.g
´´´Response to long, see console´´.
I havent connected the expansion board, yet. Is this a problem?
