Z-Probe Problems after Update from 3.0 to 3.1.1
i have done an Update from 3.0 to 3.1.1 on my Duet Maestro. So now i have Problems with my Z-Probe with an inductive Sensor.
Message in Console:29.6.2020, 10:01:16 Error: Z probe already triggered before probing move started 29.6.2020, 10:01:15 Error: Z probe already triggered at start of probing move 29.6.2020, 10:01:14 Error: Z probe already triggered at start of probing move 29.6.2020, 10:01:13 Error: Z probe already triggered at start of probing move 29.6.2020, 10:01:12 G32 Error: Z probe already triggered at start of probing move
I thing the Problem is to invert the Z-Probe. This was changed in 3.1?
So i tryed to change it.
My 3.0 Config:; Z-Probe M558 P5 C"zprobe.in" H8 F60 B0 I1 T12000 ; set Z probe type to switch and the dive height + speeds G31 P500 X5 Y35 Z3.15 ; set Z probe trigger value, offset and trigger height M557 X12.5:230 Y40:225 P3:3 ; define mesh grid
So i changed it now to:
; Z-Probe M558 P5 C"^zprobe.in" H8 F60 B0 T12000 ; set Z probe type to switch and the dive height + speeds G31 P500 X5 Y35 Z3.15 ; set Z probe trigger value, offset and trigger height M557 X12.5:230 Y40:225 P3:3 ; define mesh grid
But it doesnt work
Can anyone help me?
To invert the probe signal you need to use
. The^
is used to enable the pullup resistor.You should also verify that 3.1.1 is actually installed be sending M115.
Also, send M98 P"config.g" and report any error messages.
@Phaedrux said in Z-Probe Problems after Update from 3.0 to 3.1.1:
To invert the probe signal you need to use !. The ^ is used to enable the pullup resistor.Thank You that was it
M115 reports Firmware 3.1.1M98 P"config.g" reports:
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C Error: Can't change sensor number of existing heater Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 208C
It looks like i must change the Heater Configs!?
Regards Manuel
@Twister said in Z-Probe Problems after Update from 3.0 to 3.1.1:
Please post your entire config.g
Here my config.g:
; Configuration file for Duet Maestro (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.3 on Tue Nov 26 2019 11:04:32 GMT+0100 (Mitteleuropäische Normalzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CorEssentials" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes backwards in stealthchop mode M569 P1 S0 ; physical drive 1 goes backwards in stealthchop mode M569 P2 S1 ; physical drive 2 goes forwards in stealthchop mode M569 P3 S0 ; physical drive 3 goes forwards in stealthchop mode M569 P4 S1 ; physical drive 4 goes forwards in stealthchop mode M569 P5 S0 D2 ; physical drive 5 goes backwards in spreadcycle mode M569 P6 S0 D2 ; physical drive 6 goes backwards in spreadcycle mode M584 X5 Y6 Z0:1:2:3 E4 ; set drive mapping M671 X-35:-35:275:275 Y40:203:203:40 S10 ; position of z belts M350 X16 Y16 Z16 E16 I0 ; configure microstepping with interpolation for X Y Z E M92 X80 Y80 Z400 E415 ; set steps per mm M566 X300 Y300 Z60 E120 ; set maximum instantaneous speed changes (mm/min) ;M566 X900 Y900 Z60 E120 ; set maximum instantaneous speed changes (mm/min) M203 X24000 Y24000 Z6000 E6000 ; set maximum speeds (mm/min) M201 X3000 Y3000 Z1000 E1500 ; set accelerations (mm/s^2) ;M201 X9000 Y9000 Z1000 E1500 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X240 Y256 Z270 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop ; Z-Probe M558 P5 C"!zprobe.in" H8 F60 B0 T12000 ; set Z probe type to switch and the dive height + speeds G31 P500 X5 Y35 Z3.15 ; set Z probe trigger value, offset and trigger height M557 X12.5:230 Y40:225 P3:3 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit M308 S2 P"ctemp" Y"thermistor" A"Chamber" T100000 B3950 ; configure sensor 2 as thermistor on pin ctemp M950 H2 T2 ; Fans M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Coldend" S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"Part" S0 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency M106 P2 C"Chamber" S0 I0 F1000 H2 T45 ; set fan 2 value. Thermostatic control is turned on ; LED M950 P0 C"e1heat" Q1000 ; Tools M563 P0 D0 H1 F1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.15 ; set extruder 0 pressure advance to 0.15 seconds ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory T0 ; select first tool
How about config-override.g as well.
Compare your heater block to the one I just generated in the configurator.
Yours:
Generated:
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"ctemp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin ctemp M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2
Note the extra values for the chamber heater. Do you have an active heater for the chamber or is it just to monitor.
I think to invert the probe you need an ! rather than the ^. I think that ^ just enables a pull up resistor.
Edit: I see I'm late to the game.
@Phaedrux here is my config-override.g :
; config-override.g file generated in response to M500 at 2019-12-06 17:11 ; This is a system-generated file - do not edit ; Heater model parameters M307 H0 A183.1 C296.0 D2.1 S1.00 V24.2 B0 M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0 ; Workplace coordinates G10 L2 P1 X0.00 Y0.00 Z0.00 G10 L2 P2 X0.00 Y0.00 Z0.00 G10 L2 P3 X0.00 Y0.00 Z0.00 G10 L2 P4 X0.00 Y0.00 Z0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 G10 L2 P9 X0.00 Y0.00 Z0.00
With your generated Heater config the M98 output this:
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C Error: Pin 'e1heat' is not free Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 208C
I have no Chamber Heater (Heat up with Heatbed), only a Temperature Sensor and 2 Macros to power on the Chamber Fans:
Macro Chamber ABS:
Macro Chamber PLA:
M106 P2 C"Chamber" S0 I0 F1000 H2 T20
In that case you could remove this part
Thx
so i see the Chamber Temp. in the Extra Tab in the WebIF. Is it possible to show up the Chamber Temp. in the Display?
Where do you mean? A screen shot says a thousand words.
Hello again,
here in the Webinterface i see under Extras the Chamber Temperature Sensor (Sensor 2):
Can i rename it, so that appears "Champer Temperature" in the WebInterface?
And is it possible to show up the Temperature in the PanelDue Display?
Are you using the code snip I posted? I did not include a name like yours did. So add an A"Chamber Temperature" to the M308.
Unfortunately not at this time.
https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Limitations
Thank You! It works now fine
