UNSOLVED Z Probe Error
Hi Team,
The other day I ran a print successfully before trying to print again.
I ran M502 M500 G32 commands before attempting to run the next print.
I get the following Errors
G32
Error: Z probe was not triggered during probing move
Error: Z probe already triggered at start of probing moveIs anyone able to help me understand what the issue might be?
Here are my Gcode settings:
M503
M111 S0
M550 PT1250
M551 PM540 P0x02:0x80:0xC2:0x02:0x00:0x3E
M552 P192.168.20.5
M554 P192.168.20.1
M553 P255.255.255.0
M552 S1M555 P2
G21
G90
M83M106 P0 H-1
M106 I0
M106 S0
M106 P1 T50 H1 S255
M106 P2 T30 H100 S0.5M569 P0 S1
M569 P1 S0
M569 P2 S0
M569 P3 S0
M569 P4 S0
M574 X2 Y2 Z2 S1M665 L457.6 R266.6 H677 B175
M666 X0 Y0 Z0
M584 X2 Y4 Z3 E0M92 X160 Y160 Z160
M350 X16 Y16 Z16 E16 I1
M906 X1700 Y1700 Z1700 E1300 I40
M201 X4000 Y4000 Z4000 E4000
M203 X36000 Y36000 Z36000 E18000
M566 X500 Y500 Z500 E500M305 P0 T100000 B4267 R4700 H30 L0
M305 P1 B4725 C7.060000e-8M307 H0 A119.9 C608.9 D1.4 S1.00 B1
M570 H0 P20 T60
M570 H1 P15 T10M563 P0 D0 H1
G10 P0 S0 R0
M92 E308M558 P4 X0 Y0 Z0 F120 T18000
G31 X0 Y0 Z-0.1 P500M556 S78 X0 Y0 Z0
M208 S1 Z-0.5M143 S301
M143 H0 S101M911 S20.5 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
M579 X1.0068 Y1.0127
M912 P0 S-2M307 H3 A-1 C-1 D-1
M42 P3 S0M581 E1 S1 T1 C0
M557 R150 S20
M501
G28
@oneearthtech since G32 calls your bed.g you should also post that. There might be something in it that causes the issue. Also you called M500 so you saved some setting in the config-override.g can you post that too?
Also you are calling your config-override.g and then homing all. So does it home okay?
hey @baird1fa
Yes the Printer home ok from what I can tell.
Sure here they are below:
bed.g
G28
G30 P0 X0.00 Y165.00 Z-99999 H0
G30 P1 X106.06 Y126.40 Z-99999 H0
G30 P2 X162.49 Y28.65 Z-99999 H0
G30 P3 X142.89 Y-82.50 Z-99999 H0
G30 P4 X56.43 Y-155.05 Z-99999 H0
G30 P5 X-56.43 Y-155.05 Z-99999 H0
G30 P6 X-142.89 Y-82.50 Z-99999 H0
G30 P7 X-162.49 Y28.65 Z-99999 H0
G30 P8 X-106.06 Y126.40 Z-99999 H0
G30 P9 X0.00 Y82.50 Z-99999 H0
G30 P10 X71.45 Y41.25 Z-99999 H0
G30 P11 X71.45 Y-41.25 Z-99999 H0
G30 P12 X0.00 Y-82.50 Z-99999 H0
G30 P13 X-71.45 Y-41.25 Z-99999 H0
G30 P14 X-71.45 Y41.25 Z-99999 H0
G30 P15 X0 Y0 Z-99999 S9
G28config-override.g
; Delta parameters
M665 L457.600 R266.600 H677.000 B175.0 X0.000 Y0.000 Z0.000
M666 X0.000 Y0.000 Z0.000 A0.00 B0.00
; Heater model parameters
M307 H0 A119.9 C608.9 D1.4 S1.00 V0.0 B1
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
@oneearthtech okay. So did everything work before you saved the config-override.g for the first time. Then after that it stopped working? Perhaps erase the data I. The config-override.g and see if things work again. That will tell you if there is something in the config-override.g that is the issue.
Looking through your config.g it seems like some parameters are missing when setting up the probe. The M558 P4 F120 T18000 is okay but where are you telling it which pin to use? If you have recently updated your firmware that could be your issue. In the new firmware you have to define the input for the sensor. It looks like you are setup for old firmware that just assumes you are using z end stop input.
Try using
M558 P4 C”zstop” H5 F120 T18000.It could also be that you are missing the H parameter too. The Hparameter is the probe height, but without it, it should default to 5 anyway.
Hey @baird1fa
Ok I will try erasing the config override info and see what happens.
I am using very old firmware as the manufacturer of my printer has advise me not to upgrade as they will provide a firmware for me. I assume there is good reason for this.
Unfortunately erasing the config override files has no affect.
adding C"zstop" made things worse.
@oneearthtech the C parameter is only for newer firmware so that shouldn’t be your issue.
I guess I’m not much help. Sorry.
@baird1fa thanks so much for trying to help.
What firmware version? What Duet board? What probe type?
Firmware Electronics: Duet Ethernet 1.02 or later
Firmware Version: 2.0(RTOS) (2018-06-05b3)
Web Interface Version: 1.21.1Z-Probe
Type:
E0 Switch (4)
Trigger Height:
-0.1 mm
Trigger Value:
500M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet Ethernet 1.02 or later
Board ID: 08DDM-9FAM2-LW4SD-6J1F0-3SJ6T-TLZ7Z
Used output buffers: 3 of 20 (6 max)
Static ram: 28380
Dynamic ram: 95568 of which 60 recycled
Exception stack ram used: 396
Never used ram: 6668
Task NETWORK ready, free stack 908
Task HEAT blocked, free stack 1256
Task MAIN running, free stack 3548
Last reset 00:06:34 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6632 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 12.2ms
MCU temperature: min 32.8, current 35.6, max 36.1
Supply voltage: min 24.0, current 24.3, max 24.9, under voltage events: 0, over voltage events: 0
Driver 1: standstill, SG min/max 0/0
Driver 2: standstill, SG min/max 0/1023
Driver 3: standstill, SG min/max 0/1023
Driver 4: standstill, SG min/max 0/287
Slowest loop: 76.11ms; fastest: 0.07ms
Hiccups: 8, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 237, MaxWait: 1680913463ms, Underruns: 0, 0
Scheduled moves: 121, completed moves: 121
Bed compensation in use: none
Bed probe heights: -3.242 -2.990 -3.276 -4.084 0.000
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 7.75ms; fastest: 0.01ms
HTTP sessions: 1 of 8
Interface state: 5
@oneearthtech said in Z Probe Error:
Is anyone able to help me understand what the issue might be?Well if your probe is a simple switch I would start to look at the switch hardware and wiring. Has anything changed recently with it?
If you send a simple G30 do you get the same errors?
