BL Touch flashes after homing z
hey,
I can maka a normal homing z and after it, the BL isn´t working anymore. no m401 / m402( when pushed manually in). It is also flashing red... I can´t stop it.
Sometimes it calls ´´already triggered´´ when trying G32Duet 3
M303 H0 P1 S65
Status
Idle
Mode: FFF
Tool Position
X
35.0
Y
35.0
Z
232.60
Extruder Drives
Drive 0
0.0
Drive 1
0.0
Drive 2
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
24.0 V
V12
12.2 V
MCU Temperature
39.8 C
Z-Probe
1000
Tools
Extra
Control All
Tool Heater Current Active Standby
Tool 0
T0 - Load Filament Heater 1
off 21.0 C
0
0
Bed Heater 0
active 20.8 C
0
0
Temperature Chart
Macros Directorysys
0:/macros/sys/config.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"Duet 3" ; set printer name; Drives
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M569 P1.1 S1 ; physical drive 1.1 goes forwards
M569 P1.2 S1 ; physical drive 1.2 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X750 Y750 Z800 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in; Z-Probe
M558 P9 C"io4.in" H15 F120 T1200 ; set Z probe type to bltouch and the dive height + speeds
M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
G31 P500 X-20 Y-20 Z4 ; set Z probe trigger value, offset and trigger height
M557 X15:650 Y15:650 S60 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M307 H0 S1 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M671 X-12:92:92:-12 Y185:185:615:615 S4; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on powerdeploy----------------------------
; deployprobe.g
; called to deploy a physical Z probe
M280 P0 S10 ; deploy BLTouchretract.g--------------------------------
; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouchhomez.g-------------------------
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit)
G91 ; relative positioning
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bedDuet Web Control 3.1.1
@barbarossa-cologne said in BL Touch flashes after homing z:
I would check wiring first and whether the core has the right position (allen key on top of the BLtouch).
I would change G31 P500 ... to P25.
I don't know whether io4 needs a pullup resistor at the Duet3, in this case would be necessary to set the ^: M558 P9 C"^io4.in" H15 F120 T1200
=> I found an old thread where you need pullup for both M558 and M950:
M950 S0 C"^io4.out"Probably nothing to do with the problem, but you have 3 mappings for E, but 6 values for E at the following settings.
Using your pins in the configurator I get this:
; Z-Probe M950 S0 C"io4.out" ; create servo pin 0 for BLTouch M558 P9 C"^io4.in" H5 F60 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P25 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
So you may need the pullup ^ enabled on io4.in
The other thing I notice is that your homez places the probe outside the bed if your G31 X Y offsets are correct.
G31 P500 X-20 Y-20 Z4 ; set Z probe trigger value, offset and trigger heightAlso Z4 for a trigger height seems very high for the BLtouch.
What is in your homeall?
It was the thread https://forum.duet3d.com/topic/15823/duet-3-inverted-pull-up-inverted-pull-up where it was told that io4.in and io4.out should be pulled up with ^ with the Duet3.
@JoergS5 said in BL Touch flashes after homing z:
What do you mean with it and how can I change this?
This post is deleted!
@JoergS5
Yes.. thank you. But the problem is still, that the no touch flashes after doing a z probe. Z probe, but then I have to deconnect the cable and then it's working. M401 / M402.
Also after successfully probe the first point (G32) it's stopping,and it says ''z probe was not triggered during probing move''.
@barbarossa-cologne it is some time ago, so I don't remember well.
First you should update to firmware 3.1.1, if you have an older version.
Then please make an image of the BLtouch 5-pin connector and the wiring on the Duet to check wiring.
In the meantime I know that
M558 P9 C"io4.in" H5 F60 T6000
doesn't need ^ because it already has pullup acticated automatically.
Post your homeall.g and bed.g please.
Duet 3 g32 Status Idle Mode: FFF Tool Position X 35.0 Y 35.0 Z -12.50 Extruder Drives Drive 0 0.0 Drive 1 0.0 Drive 2 0.0 Speeds Requested Speed 0 mm/s Top Speed 0 mm/s Sensors Vin 24.0 V V12 12.1 V MCU Temperature 44.8 C Z-Probe 0 Tools Extra Control All Tool Heater Current Active Standby Tool 0 T0 - Load Filament Heater 1 off 25.9 C 0 0 Bed Heater 0 fault 25.9 C 70 0 Temperature Chart Macros Directory > sys 0:/macros/sys/homeall.g ; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z15 F2400 ; lift Z relative to current position G1 H1 X805 Y805 F1200 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X-5 Y-5 F2400 ; go back a few mm G1 H1 X805 Y805 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H1 Z-805 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z15 F40 ; lift Z relative to current position ;G90 ; absolute positioning
Duet 3 g32 Status Idle Mode: FFF Tool Position X 35.0 Y 35.0 Z -12.50 Extruder Drives Drive 0 0.0 Drive 1 0.0 Drive 2 0.0 Speeds Requested Speed 0 mm/s Top Speed 0 mm/s Sensors Vin 24.0 V V12 12.1 V MCU Temperature 44.8 C Z-Probe 0 Tools Extra Control All Tool Heater Current Active Standby Tool 0 T0 - Load Filament Heater 1 off 25.9 C 0 0 Bed Heater 0 fault 25.9 C 70 0 Temperature Chart Macros Directory > sys 0:/macros/sys/bed.g ; bed.g ; Called using G32 ; Called to perform True Autolevel using 4-point probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M561 ; clear any bed transform G29 S3; Clear bed height map ; Probe 4-point G30 P0 X150 Y135 Z-9999 ; Front Right G30 P1 X550 Y135 Z-9999 ; Front Left G30 P2 X550 Y565 Z-9999 ; Back Left G30 P3 X150 Y565 Z-9999 S4 ; Back Right
Let's try and keep it to a single thread please.
sorry
That was not my plan.....
@barbarossa-cologne in the other thread you say firmware is 3.01 beta 9, you should update to 3.1.1 first before doing anything else.
