Duet 3 SBC Low voltage
  • I keep getting a low voltage symbol (Lightening bolt)
    on my screen. I do run a small monitor from the raspberry pi. It has it's own power source. Should I plug in the raspberry pi to it's own power source ? Raspberry pi 4.
  • RPi4 requires 3A supply. I believe Duet 3 does not provide enough current. I had the same issue and had to use dedicated power supply to power RPi.
    Hope this helps.
