SOLVED defective stepper driver?
My Duet 2 Ethernet board appears to have a defective stepper driver, on driver 0 (x motor).
When attempting to home the x-axis, the board reports that driver 0 is not connected to phase A or phase B.
I double-checked my wiring to the motor, and everything is correct and has continuity. As an additional step, I connected my printer to another control board, and can successfully move the motor that was connected to driver 0 on the Duet 2 Ethernet board, further indicating that the problem is with the stepper driver chip.
Is there anything else I can try? Or is the driver defective?
Hi thanks for your patience and for providing all of the detail. I don't see anything in your config that would cause it and your troubleshooting indicates the driver has failed. Please contact filastruder to initiate a warranty replacement. Refer them to this thread.
https://forum.duet3d.com/post/165873 might help narrow down the options?
Good thoughts. I don't think those apply in this case, though. I swapped out the new (and possibly bad) duet2 with an older duet2 and used the same sd/configs on the old board which works just fine.
That leaves defective driver most likely. But providing the exact error, motor config/specs and the output of
M122
might get you some other input.
@guildner yes does sound like its defective. can you provide the M122 report and a copy of your config.g please.
Busy day at work today, but I'll get the info posted tonight.
@T3P3Tony When I'm able to get the M122 diagnostics, should I have the board on full 24V power, or would it be sufficient to just use 5V power via USB?
Here is my config:
; Jubilee 2.0 Config File ; drawing inspiration from the Railcore 300ZL config file ; Name and Identification M550 P"Cubilee" ; Machine name and Netbios name ; Networking M552 P192.168.1.2 S1 ; Use Ethernet with a static IP M554 192.168.1.3 ; Gateway M553 P255.255.255.0 ; Netmask M586 P2 S1 ; Enable Telnet ; Debugging M111 S0 ; Debug off M929 P"eventlog.txt" S1 ; Start logging to file eventlog.txt ; General Preferences M555 P2 ; Set Marlin-style output G21 ; Set dimensions to millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Joints M584 X0 Y1 Z6:7:8 E3:4:5:9 U2 ; Map Z to drivers 6, 7, 8. Map extruders to 3 and 4. Create Toolchanger Lock axis. M569 P0 S0 ; Drive 0 direction | X stepper M569 P1 S0 ; Drive 1 direction | Y Stepper M569 P6 S0 ; Drive 6 direction | Front Left Z M569 P7 S0 ; Drive 7 direction | Front Right Z M569 P8 S0 ; Drive 8 direction | Back Z M569 P2 S0 ; Drive 2 direction | Toolchanger Actuator M569 P3 S0 ; Drive 3 direction | Extruder 0 M569 P4 S0 ; Drive 4 direction | Extruder 1 ;M569 P5 S0 ; Drive 5 direction | Pen 0 ; Joint Kinematics M669 K1 ; CoreXY mode ; Kinematic bed ball locations. ; Locations are extracted from CAD model assuming lower left build plate corner is (0, 0) on a 305x305mm plate. ;M671 X300:5:152.5 Y354:354:24 S10 ; Front Left: (300, 354) | Front Right: (5, 354) | Back: (152.5, 24) M671 X297:2.5:150 Y313.5:313.5:-16.5 S10 ; Front Left: (297.5, 313.5) | Front Right: (2.5, 313.5) | Back: (150, -16.5) ; Axis and motor configuration ;M350 X16 Y16 Z16 E16 U4 I1 ; Set 16x microstepping for xyz axes & extruder, 4x for toolchanger lock. Use interpolation. M350 X8 Y8 Z16 E16 U4 I1 ; Set 8x microstepping for xy, 16x for z axes & extruder, 4x for toolchanger lock. Use interpolation. M574 X1 Y1 Z1 S1 ; Set homing switch configuration x low-end, y low-end, z low-end, all active-high (NC) M574 U1 S1 ; Set homing switch configuration for toolchange lock. Both switches should be wired NC and in series. M906 X1950 Y1950 Z1750 E1250 ; Motor currents (mA) M906 U670 I60 ; LDO Toolchanger Elastic Lock Motor current and idle motor percentage. ;M906 U900 I60 ; StepperOnline Toolchanger Elastic Lock Motor current and idle motor percentage M201 X1000 Y1000 Z20 E1300 U800 ; Accelerations (mm/s^2) M203 X13000 Y13000 Z800 E8000 U9000 ; Maximum speeds (mm/min) M566 X1000 Y1000 Z500 E3000 U50 ; Maximum jerk speeds mm/minute ;M92 X200 Y200 ; Steps/mm for X,Y M92 X100 Y100 M92 U30.578 ; LDO Toolchanger Elastic Lock Motor Steps/deg for U from (200 * 4 * 13.76)/360 ;M92 U11.515 ; Stepper-Online Toolchanger Elastic Lock Motor Steps/deg for U from (200 * 4 * 5.18181)/360 M92 Z3200 ; Steps/mm for Z for a 2mm pitch leadscrew, 0.9mm stepper. (16 * 400)/2 M92 E830 ; Extruder - 0.9 deg/step ; Set axis software limits and min/max switch-triggering positions. ; Adjusted such that (0,0) lies at the lower left corner of a 300x300mm square in the 305mmx305mm build plate. M208 X-11.5:311.5 Y-44:341 Z-0.2:315 M208 U0:200 ; Set Elastic Lock (U axis) max rotation angle ; Thermistors M305 P0 S"Bed" T10000 B3435 H0 ; BOM-specified Terminal Lug Thermistor values. ;M305 P0 S"Bed" T10000 B3984 H0 L160 ; BOM-specified Terminal Lug Thermistor values. ;M305 P0 S"Bed" T100000 B3950 R4700 H0 L0 ; Built-in Keenovo Bed Thermistor values. M305 P1 X200 ; Map Extruder 0 sensor to PT100 Channel 0 M305 P2 X201 ; Map Extruder 1 sensor to PT100 Channel 1 ;Heaters M570 S30 ; Print will be terminated if a heater fault is not reset within 30 minutes. M143 H0 S100 ; Maximum H0 (Bed) heater temperature ;M143 H1 S260 ; Maximum H1 (Extruder) heater temperature ; Default heater model M307 H0 A270.7 C90.4 D6.7 B0 S1.0 ; Default Bed Heater Parameters, before tuning / if config-override.g is missing ; Tool definitions M563 P0 S"Extruder 0" D0 H1 F0 ; Define tool 0 G10 P0 X-4.5 Y44.02 Z-2.25 ; Set tool 0 offset from the bed G10 P0 S190 R170 ; Set tool 0 operating and standby temperatures(-273 = "off") M572 D0 S0.1 ; Set pressure advance on Extruder Drive 0 M563 P1 S"Extruder 1" D1 H2 F2 ; Define tool 1 G10 P1 X-4.15 Y44.62 Z-2.45 ; Set tool 1 offset from the bed with tool-0 as a reference. G10 P1 S190 R170 ; Set tool 1 operating and standby temperatures(-273 = "off") M572 D1 S0.1 ; Set pressure advance on Extruder Drive 1 ; Fans M106 P0 S0 ; Turn off fan 0 ;M106 P1 S0 ; Turn off fan 1 ;Mesh Bed Leveling Settings: M557 X10:290 Y10:290 P6 ; Z probing settings M558 P4 C2 H5 A1 T10000 S0.02 ; P4 --> probe type: switch ; C2 --> endstop number ; H5 --> dive height ; A1 --> max number of times to probe ; T100000 --> travel speed between probe points ; S0.02 --> tolerance when probing multiple times M98 P"config-user.g" ; Load custom user config M501 ; Load saved parameters from non-volatile memory
And here is the output from M122, only using 5V from USB (I can get it again later tonight while on 24V if needed.):
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet Ethernet 1.02 or later Board ID: 08DLM-996RU-N85T0-6J9F2-3SN6L-1UVRR Used output buffers: 3 of 24 (10 max) === RTOS === Static ram: 25680 Dynamic ram: 93636 of which 48 recycled Exception stack ram used: 208 Never used ram: 11500 Tasks: NETWORK(ready,644) HEAT(blocked,1180) MAIN(running,3844) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:00:50 ago, cause: power up Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10428 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 1.5ms, max retries 0 MCU temperature: min 33.5, current 37.6, max 37.9 Supply voltage: min 0.5, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Date/time: 2020-07-30 10:08:11 Cache data hit count 99036185 Slowest loop: 101.12ms; fastest: 0.06ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 3.97ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 Interface state 5, link 100Mbps full duplex
@guildner said in defective stepper driver?:
I don't think so as the drivers won't be powered when running only from 5v.
@Phaedrux cool, I'll grab that later tonight, then.
@T3P3Tony @Phaedrux Here is the output from M122 while powered from 24V:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later Board ID: 08DLM-996RU-N85T0-6J9F2-3SN6L-1UVRR Used output buffers: 3 of 24 (9 max) === RTOS === Static ram: 25712 Dynamic ram: 93156 of which 48 recycled Exception stack ram used: 272 Never used ram: 11884 Tasks: NETWORK(ready,628) HEAT(blocked,1176) MAIN(running,3760) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:06:24 ago, cause: power up Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10428 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 1.5ms, max retries 0 MCU temperature: min 34.7, current 43.4, max 43.6 Supply voltage: min 24.4, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-07-30 20:16:56 Cache data hit count 727883381 Slowest loop: 3.53ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 4.65ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 Interface state 5, link 100Mbps full duplex
And, when attempting to home I get this:
G28 X Warning: motor phase A may be disconnected reported by driver(s) 0 Warning: motor phase B may be disconnected reported by driver(s) 0
And M122 shows this:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later Board ID: 08DLM-996RU-N85T0-6J9F2-3SN6L-1UVRR Used output buffers: 3 of 24 (10 max) === RTOS === Static ram: 25712 Dynamic ram: 93156 of which 48 recycled Exception stack ram used: 432 Never used ram: 11724 Tasks: NETWORK(ready,744) HEAT(blocked,1152) MAIN(running,3728) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:03:04 ago, cause: power up Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10428 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 1.6ms, max retries 0 MCU temperature: min 38.6, current 43.6, max 43.6 Supply voltage: min 24.4, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 0/0 Driver 1: ok, SG min/max 0/0 Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-07-30 20:36:52 Cache data hit count 350466746 Slowest loop: 7.60ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 56855ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 2, completed moves: 2, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 5.46ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 Interface state 5, link 100Mbps full duplex
Can you post your homex.g?
Are you able to generate the same error by just sending
G92 X100
G91
G1 X10 F1000
Here is my homex.g file:
; Home X Axis G91 ; Set relative mode G1 X-330 F6000 S1 ; Big negative move to search for endstop G1 X4 F600 ; Back off the endstop G1 X-10 F600 S1 ; Find endstop again slowly G90 ; Set absolute mode
Yes, that generates the error
If it matters, the motor never moves at all when giving it any of these commands.
@T3P3Tony This is a brand-new board, and I am looking to get authorization to get a replacement (ordered from Filastruder).
Is there anything else you need from me?
