    Fans are lazy!
    Firmware installation
    297
    • duttiundefined
      dutti
      hey,
      my fans are at 100%, but there are working with less power.
      Before I had them on a chinese printer and the fan was much more powerful. How can I change this?
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S0 ; physical drive 1.0 goes forwards
      M569 P1.1 S1 ; physical drive 1.1 goes forwards
      M569 P1.2 S1 ; physical drive 1.2 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X700 Y700 Z800 S0 ; set axis maxima
      M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
      M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
      M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X10:600 Y10:600 S200 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0.8 H-1  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
      M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
      M671 X-19.5:99.5:99.5:-19.5 Y110:110:540:540 S2.5
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
      KR
      Richard
        Your fan0 is set to 80%
        If you want it full power at startup set it to S1.
        duttiundefined 1 Reply Last reply Reply Quote 0
        • duttiundefined
          dutti @Phaedrux
          @Phaedrux
          hm ok... but fan on out3 has ´´S1´´ as parameter and it hasn´t that normal power.
            Is it a 12v or 24v fan?
            You can try increasing the frequency of the fan PWM by changing the Q value in the M950 for that fan.
            • duttiundefined
              dutti
              24v fan.. I´ll try to change the code.
              Thanks, richard
                Looks like you are using a Duet 3. Have you set the fan voltage selection jumpers to the VIN position? Duet 3 is normally shipped with the jumpers in the 12V position.
                duttiundefined 2 Replies Last reply Reply Quote 0
                • duttiundefined
                  dutti @dc42
                  yes. duet3.
                  I haven´t changed any jumpers.
                  So I can use 12v fans when using no jumpers?
                  Also on out3?
                  Because the fan on out 3 isn´t working at all.
                  M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z1600.00 E92.70:92.70:92.70 ; set steps per mm ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
                  M906 X1200 Y1200 Z3000 E1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                  • duttiundefined
                    dutti @dc42
                    @dc42 How to switch the voltage with the jumpers?
                    Any explanation online?
                    thanks
                    whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                    • whosrdaddyundefined
                      whosrdaddy @dutti
                      @barbarossa-cologne Docs can be found here.
                      duttiundefined 1 Reply Last reply Reply Quote 1
                      • duttiundefined
                        dutti @whosrdaddy
                        @whosrdaddy
                        ok thanks.
                        But shortly... is on out7 - out9 12v when I haven´t changed any jumpers?
                        KR
                        Richard
                          whosrdaddy @dutti
                          @barbarossa-cologne : As DC42 said, standard the board is jumpered for 12V. If you read the link I gave you, you will find the following section (emphasis mine):
                          4-pin KK connectors with offset spigot OUT_4 thru OUT_6: these are intended for PWM-controllable fans. The connector fits a standard PC-type 4-pin PWM fan. Alternatively, a 2-pin fan may be connected between the V_OULCn pin (+ve) and the OUT_n_NEG pin (-ve). The positive supply to these connectors is the centre pin of the 3-pin jumper block labeled OUT4-OUT6_Select. A jumper in the top position will power them from the fused VIN supply. Alternatively you can connect a 3-terminal buck regulator to the 3-pin jumper block to supply the required voltage to the centre pin.
                          Seeing that you are using OUT7-OUT9, you must set the correspondend selection jumper to VIN, look at the hardware drawing at the link I gave you...
                          • duttiundefined
                            dutti @whosrdaddy
                            @whosrdaddy
                            Thanks...
                            This is maybe useful.....
