    duet 3 connecting z probe inductive sensor
    1.5k
    • Vetiundefined
      Veti
      can you show us your new wiring
      aprzundefined 1 Reply Last reply Reply Quote 0
      • aprzundefined
        aprz @Veti
        @Veti Here it is. Picture 1 shows the signal wire connected to io5.in and picture 2 shows the positive and negative wires in 12v supply.
        8F35663A-DB96-410E-AB41-A392A2A1ED8B.jpeg 9DEAE847-AC3A-45BA-BEFA-5D682EE716C3.jpeg
          Phaedrux Moderator @aprz
          @1997alex said in duet 3 connecting z probe inductive sensor:
          @Phaedrux This is the exact one. looks like the pnp style sensors require a resistor?
          https://www.amazon.com/Twidec-Inductive-Proximity-Detecting-LJ18A3-8-Z/dp/B07WS45K3P/ref=sr_1_1?dchild=1&keywords=b07ws45k3p&qid=1599193793&sr=8-1
          Ok, so it's a PNP NO sensor not NPN.
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_PNP_output_normally_open_inductive_or_capacitive_sensor
          See if this makes a difference.
          • aprzundefined
            aprz
            Ok,I ordered a few 10k, 30k and 68k resistors. I’ll follow up on how it comes out or whether it works. Here’s a drawing of how I’m understanding from the article how to connect the resistor to the duet and sensor. If this doesn’t work I’ll just buy a npn sensor. The yellow lines are the two resistors tied together and connected to ground and sensor wire.by the way the positive is going to be connected to 12v pin. Correct me if I’m wrong or a potential .
            • aprzundefined
              aprz
              Ok never mind the resistors, I’ll try that out later but I just ordered another probe that is a npn swapped it out. It works just had to fix a couple wiring issues but anyone out there wanting to use a inductive sensor make sure it’s a npn inductive sensor, also the sensor works with the 3.3v power in the io5 pin and didn’t need to wire it to the vin or 12v. I have the brown going to 3.3v, the blue going to ground and the black going to “io5.in”. Well thanks for the help problem solved.👍
