UNSOLVED Damaged Duex5? Endstop LED on with nothing connected
The LED for
duex.e6stop
is lit with nothing connected. If I connect an NC switch, it lights brighter. When I physically close the switch, it dims back down.Compared to other printers, the
M580
triggers on different stops take a very long time to trigger. If I have a switch connected toduex.e6stop
and click it, the printer hangs.If I disconnect the duex entirely and attach the trigger switch to
zstop
, it triggers quickly, and every time I click it.
duex.e6stop is actually a pin on the duet2 board's processor so while its possible the issue is with the duex board I'd test pin 24 directly on the 50 pin expansion before expecting a new duex to resolve the issue. (with a minimal config)
also, does having the config enable pull up make any difference with the NC switch not connected and led being lit?
