    Please tell me about the config of the polar printer.
    Firmware installation
    • MRJEON
      MRJEON last edited by
      M669 K7 R0:150 H0.3 F30 A30 ; set Polar kinematics parameters
      Knnn Geometry class, 7 = Polar
      Raaa:bbb Minimum and maximum radius in mm. If only one value it given it will be used as the maximum radius, and the minimum radius will be assumed to be zero.
      Hnnn Radius in mm at which the homing switch is triggered during a homing move. If this parameter is not present, the homing switch is assumed to trigger at the minimum radius.
      Fnnn Maximum turntable speed in degrees per second
      Annn Maximum turntable acceleration in degrees per second per second
      Suppose the turntable is the y-axis. So, where are the x-axis settings?
        The X motor is the radius motor. The R parameter specifies the minimum and maximum radii that are reachable by the nozzle. The M92 X parameter specifies the radius motor steps/mm. Does that help?
