    Can the Duet Expansion Breakout Board be connected to DUET 3?
    • MRJEON
      MRJEON last edited by
      Or can you only connect to DUET 2? Is there a separate duet 3 expansion board?
      Veti 1 Reply Last reply Reply Quote 0
      • Veti
        Veti @MRJEON last edited by
        duet 2 expansion board is not compatible with duet 3.
        duet3 uses can-bus for expansion
        duet 3 expansion board is here https://www.duet3d.com/Duet3Expansion3HC
        • A Former User
          as above, but there are also the 1LC tool board and for weird custom stuff you can also use the development board linked below. dc42 has written a bootloader and firmware for it to act as an expansion board
          • https://www.chip45.com/products/sammy-c21-1.0_atmel_smart_arm_sam_module_board_samc21_usb_dual_two_can.php
          • https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3
          • https://github.com/Duet3D/Duet3Expansion/tree/master/src/AtmelStart_SAMC21
