Dual Z setup help
ok so far i have both z's working in tandem on z1 and e0. I can do a true level and a mesh level. What else could i do to ensure the bed is as level as possible via the dual z setup on the board? i swear i saw an walkthrough last night that talked about probing at the lead screws and syncing them up some how.
now you need to find the lead screw position in x and y coordinates
in the example
the first is a position x-20 y0
the second is x220 y0
M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axisthen you need to create the bed file and put in a position close to the leadscrews that you can probe on the bed
in this example we choose X20 Y0 for the first and X180 Y0 for the second
bed.gG28 ; home
G30 P0 X20 Y0 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X180 Y0 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors -
ok just so i get this right and not piss my self off. i measure with calipers from the lead screw to the probe? Or the nozzle? i havent had enough coffee or calm sanity from having to also teach my 2nd grader since schools are not "open" in our area yet.
from the nozzle.
the nozzle is the point of reference
ok this is what i got and filled in the areas. On the left side lead screw i have a measurement of 154.3mm from lead screw to nozzle. And on the right side i have a measurement of 89mm from lead screw to nozzle. and since i have the nozzle lined up on both lead screws i took those measurements and added on the right and subtracted on the left. If i did this wrong let me know.
M671 X-84.3:419 Y0192:192 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
bed.g
G28 ; home
G30 P0 X70 Y192 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X330 Y192 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors -
now give it a try and run G32.
i did and its working wonderfully thank you so much for the help and understanding. right now im printing extra parts just so i dont have to go through this entire process again if a print decides to break my bltouch mount and force me to use a fan and bltouch mount that removes the x axis switch.
you can even print a bltouch replacement. https://www.thingiverse.com/thing:3303618
Really hum didnt even know that.
