    RRF 3.1.1 Probe Issues
    66
    • MichaelMD1978
      MichaelMD1978 last edited by
      Hello Guys, I just can't seem to find an answer on my Issue. I was running 2.05.1 and everything was working well, so I decided to make my life difficult and move to 3.1.1 and now I am having some trouble with my Probe. Before there would always be a double probe action, it would probe once fast and once slow in each spot, now it only probes each point once? Has anyone else noticed this and how can I fix it?
        Most likely you do not have the correct M558 command in config.g. Please post your config.g file.
        MichaelMD1978 1 Reply Last reply Reply Quote 0
        • MichaelMD1978
          ; Configuration file for Duet WiFi (firmware version 3.1.1)
          M550 P"BLV AM8" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P4 S1 ; physical drive 4 goes forwards
          M584 X0 Y1 Z2:4 E3 ; set drive mapping
          M671 X0:220 Y110:110 S2 ; leadscrews left & right (Middle of the bed in the Y axis)
          M350 X16 Y16 Z16 E16 I0 ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E400.00 ; set steps per mm
          M566 X1000.00 Y1000.00 Z40.00 E1000.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z1000.00 E6000.00 ; set maximum speeds (mm/min)
          M201 X2500.00 Y2500.00 Z100.00 E2500.00 ; set accelerations (mm/s^2)
          M906 X1500 Y1500 Z720 E1500 I45 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-4 Y-50 Z0 S1 ; set axis minima
          M208 X220 Y210 Z250 S0 ; set axis maxima
          M574 X1 S1 P"!xstop"
          M574 Y1 S1 P"!ystop" ; set active low and disabled endstops
          M574 Z1 S2 ; set endstops controlled by probe
          M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X0 Y37.5 Z0.70 ; set Z probe trigger value (was at P500, I am testing P1000), offset and trigger height (Higher is closer to the bed!)
          M557 X10:210 Y10:210 S10 ; define mesh grid
          ; Bed
          M308 S0 P"bed_temp" Y"thermistor" T100000 B4138 R4700 ; New Value for 3.1.1
          M950 H0 C"bed_heat" T0 ; New Value for 3.1.1
          M307 H0 A135.7 C683.7 D2.1 V11.8 B0 S1.00 ; Disable bang-bang mode and add PID Values for the bed heater and set PWM limit
          M140 H0 ; Map Heated Bed to Heater 0 on the GUI
          M143 H0 S120 ; Set the Bed Max Temp to 120 Degrees
          ; Hotend
          M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F50 ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
          M950 H1 C"e0_heat" T1 ; New Value for 3.1.1
          M307 H1 A636.2 C264.9 D5.8 V11.8 B0 S1.00 ; disable bang-bang mode and set PID Values for the Hotend heater and set PWM limit
          M143 H1 S270 ; Set the Hotend Max Temp to 270 Degrees
          ; Chamber
          M308 S2 P"e1_temp" Y"thermistor" T100000 B4138 C0 R4700 ; New Value for 3.1.1
          M950 H2 C"e1_heat" T2 ; New Value for 3.1.1
          M307 H2 A42.6 C3913.4 D5.0 V12.2 B0 S1.00 ; Chamber PID Values - Testing These!
          ;M307 H2 A11 C99000 D2000 B1 ; chamber heater operates in bang-bang mode
          M141 H2 ; Map Heated Bed to Heater 0 on the GUI
          M143 H2 S80 ; Set the Chamber Max Temp to 80 Degrees
          ; Part Fan
          M950 F0 C"fan0" Q500 ; New Value for 3.1.1
          M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          ; Hotend Fan
          M950 F1 C"fan1" Q500 ; New Value for 3.1.1
          M106 P1 S1 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          T0 ; select first tool
          • A Former User
            Dunno if this is considered the correct way to do it or not but what works for me is the following
            in my homeall.g files
            ; homeall.g
            ; called to home all axes
            G91                     ; Relative positioning
            G1 H2 Z5 F6000          ; Lift the Z axis
            G1 H1 X-320 Y-320 F7000 ; Move the X & Y axis's quickly towards their end stops (First Pass)
            G1 H2 X5 Y5 F8000       ; Then go back a few mm
            G1 H1 X-320 Y-320 F1000 ; Then Slowly approach the X & Y end stops (Second Pass)
            G1 X155 Y168 F7000      ; Go to the centre of the bed
            M558 A1 F600	        ; Set a single probe move at a faster feed rate to get the nozzle closer to the bed
            G30                     ; home Z by probing the bed
            M558 A1 F100	        ; Set the second probing at a slower feed rate
            G30	                ; Probe a second time to get a more accurate position
            G1 Z5 F1000             ; Lift the Z axis
            G90                     ; Absolute positioning
            MichaelMD1978 1 Reply Last reply Reply Quote 1
            • MichaelMD1978
              MichaelMD1978 @dc42 last edited by
              @dc42 If you see anything else in my config that could be wrong, please let me know. The Probe is a Pinda 5v
              • MichaelMD1978
                MichaelMD1978 @Guest last edited by MichaelMD1978
                @CaLviNx Thanks, I will give this a try. I would rather fix the M558 in config.g though as this also happens in my mesh levelling.
                A Former User 1 Reply Last reply Reply Quote 0
                • A Former User
                  A Former User @MichaelMD1978 last edited by
                  @MichaelMD1978 said in RRF 3.1.1 Probe Issues:
                  in the config.g you can also specify the amount of times it carries out a probe A command
                  MichaelMD1978 3 Replies Last reply Reply Quote 0
                  • MichaelMD1978
                    @CaLviNx Thanks
                    • MichaelMD1978
                      @CaLviNx how would that look in the config.g?
                      • MichaelMD1978
                        @CaLviNx This is my current M558:
                        How do I edit that to probe twice?
                        fcwilt 1 Reply Last reply Reply Quote 0
                        • A Former User
                          A Former User @MichaelMD1978 last edited by A Former User
                          To be honest in RRF-3 im not exactly sure how you go about getting any subsequent probe to be of a differing speed to the initial probe, I would surmise there is some young pup of a computer whizz out there who can whip up some conditional g-code to do what you are asking.
                          Me myself and i would start by trying multiple copies of M558 both with A1 in the command but differing feed rates, the worst that can happen is that it doesn't work and you need to work out another solution.
                          • A Former User
                            M558 P5 C"zprobe.in" H5 A1 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                            M558 P5 C"zprobe.in" H5 A1 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                            Thats what i would try first but as i said it might not be the right way to do it.
                            • MichaelMD1978
                              @CaLviNx Thanks for the help mate, I will give it a try.
                              • fcwilt
                                fcwilt @MichaelMD1978 last edited by
                                You need to add the A and S parameters.
                                If you wish to force it to always probe twice use A2 S-1. It will average the 2 readings. If A was 5 it would average 5 readings, etc.
                                If you wish to have it try to obtain two consecutive readings that are close in value you would use something like A5 S0.1
                                With those values it would would probe up to 5 times until 2 readings were within 0.1.
                                If it failed to obtain 2 readings within 0.1 it would average the 5 readings.
                                Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. Using Duets (2 and 3) running 3.4.0
                                MichaelMD1978 A Former User 2 Replies Last reply Reply Quote 1
                                • MichaelMD1978
                                  MichaelMD1978 @fcwilt last edited by
                                  @fcwilt Thank you! That's perfect!
                                  • A Former User
                                    A Former User @fcwilt last edited by
                                    @fcwilt said in RRF 3.1.1 Probe Issues:
                                    Yes that works to do multiple same speed probes but doesn't answer his initial question
                                    • MichaelMD1978
                                      @CaLviNx Thanks for all your help too mate, I don't really need them to probe at different speeds, just having it probe twice will also work for me.
                                      • A Former User
                                        @MichaelMD1978
                                        Even if this is not really required by you, the point it raises it would be interesting to find if there is a solution.
                                        • jay_s_uk
                                          jay_s_uk last edited by
                                          at the moment, I believe the solution you're using is the only one @CaLviNx
                                          I use the same thing. I think it's on the "list" to be looked at to allow different homing speeds i.e. fast and slow.
                                          Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
                                          • fcwilt
                                            fcwilt @Guest last edited by
                                            @CaLviNx said in RRF 3.1.1 Probe Issues:
                                            @MichaelMD1978
                                            Well as you have determined the F parameter controls the probing speed.
                                            That would seem to qualify as a solution.
                                            When homing using endstop sensors the typical code has always include changes in the F parameter for the G1 commands.
