    wiring images for Anycubic chiron to duet3d conversion
    • behold
      behold last edited by
      Re: Anycubic Chiron + Duet2Wifi = Success
      I am looking for wiring images or advice on how to finish my chiron trigorilla to duet3d conversion.
      I am especially perplexed by the moffset board for the heaters, the dual z limit switches and z probe... Heck Im pretty confused in general.
      I felt like I was prepared to do this but now am concerned that I am in over my head.
      • jay_s_uk
        jay_s_uk last edited by
        The external mosfet for the heated bed will still be needed as the bed can pull more power than can be delivered. They would be wired to a heater or bed output as normal.
        This page gives information about Z axis levelling with 2 endstops. https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Axis_levelling_using_endstops
        Making sure you're on RRF3 will make it much easier.
        And what are you unsure about with the Z Probe? There is also scope to ditch the z limit switches if they are on the lower end and just rely on the z probe.
        • behold
          I am mostly confused about using the boards and connectors internal to the Chiron or eliminating them altogether and just running new leads directly.
          I like them. They make the system cleaner, but there is not much documentation on them.
          The extruder housing, in particular, warrants me to trace the connections. I have no experience with that.
          No time like the present, I guess. I am just intimidated. 😕
