Homming problems for openPNP
I am setting my Duet2 wifi for openpnp.
My machine has 1 X axis, 2 individual Y axes, 1 Z axis, and 1 E axis (nozzle).
Homming works fine for all axes except E axis.
I have tested the E endstop and the boarde detects fine, but when I send a "G1 H1 E-360 F1000" or "G1 H2 E360 F1000 " command when the board detects zero the motor keeps rotating.
I don't see where I can go wrong, I am attaching my machine settings.
Thnaks you
Jose
config.g
; Configuration file for factory testing Duet Ethernet and Wifi with V2.05.1 firmware ;******************************************************************************************************************* ;FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer! ;******************************************************************************************************************* M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M550 P"JasPnP" ; set printer name ; Communication and general M111 S0 ; Debug off M550 PDuetJAS ; Machine name and Netbios name (can be anything you like) M551 Preprap ; Machine password (used for FTP) *** Ethernet networking: The following lines are used for factory testing - PLEASE REMOVE THEM M552 P192.168.1.188 ; IP address M554 P192.168.1.255 ; Gateway M553 P255.255.255.0 ; Netmask ;*** End of factory test lines to be removed ;*** Networking M552 S1 ; Turn network on M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S1 T0 ; enable Telnet, TLS OFF ; Axis and motor configuration M569 P0 S1 ; X physical drive 0 goes forwards M569 P1 S1 ; Y right physical drive 1 goes forwards M569 P2 S1 ; Y left physical drive 2 goes forwards M569 P3 S0 ; Z physical drive 3 goes backwards M569 P4 S1 ; E0 physical drive 4 goes forwards M350 X16 Y16:16 Z16 E16 I1 ; configure microstepping with interpolation M906 X800 Y800:800 Z800 E500 I50 ; set motor currents (mA) and motor idle factor in per cent M584 X0 Y1:2 Z3 E4 ; set visibles drive M84 S40 ; Set idle timeout M92 X80.00 Y80.00:80 Z80 E8.888 ; set steps per mm M566 X200.0 Y200.0 Z200.0 E200 ; set maximum instantaneous speed changes (mm/min) M203 X22000.00 Y22000.00:22000.00 Z22000 E22000 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00:1500.00 Z1500 E1500 ; set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z-30 E-360 S1 ; set axis minima M208 X400 Y400 Z100 E360 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"ystop+zstop" ; configure active-low endstop for low end on doble Y via pin ystop M574 Z2 S1 P"e0stop" ; configure active-low endstop for low end on Z via pin zstop M574 E1 S1 P"!^e1stop" ; configure active-low endstop for low end on E0 via pin zstop ; Activa triggers ;M581 X S1 T3 C0 ; Enable endstop X to trigger triger3.g while machining ; Mosfet outputs M950 P0 C"e0heat" ; Vacuum valve output M950 P1 C"e1heat" ; Up camera lights output M950 P2 C"bedheat" ; Vacuum pump output ; Tools M563 P0 D0 ; define tool 0. T0 ; select first tool
The extruder axis don't get homed. You can set an absolute position with M92 E# if you need, but homing moves don't apply.
Are you using E as an extruder or is it a linear axis? If it's not an extruder, use a different axis letter for it, like U, then you can configure it and treat it just like XYZ.
I have very little familiarity with openpnp.
@qlfecv said in Homming problems for openPNP:
Also, all commands that aren't gcode/mcode must be commented out with a
This might be a good start as well to ensure you have all the relevant commands.
As I said recently in another PnP thread, extruders are not axes. I suggest you create a new axis (e.g. C) for the nozzle rotation, using M584.
@dc42 I think this is a different person.
@Phaedrux said in Homming problems for openPNP:
Nice that more folks are using Duet+RRF in OpenPnP systems! We should add a wiki page on configuring RRF for OpenPnP.
Thanks for reply.
I have created the C axis and everything solved.
Also modify the configuration in openPNP to work with the new C axis.
I only found this post that publishes the config.g of an openPNP machine and uses the extruder for the nozzle in it, so don't create the C axis before.
It would be of great help a wiki page to people who want to use Duet on an openPNP.
Thanks for reply.
I'm glad you got it working.
I don't have a PnP machine, so although I can create the wiki page I would need input from you and/or other PnP users. If I create the page, can you add some content?
@dc42 said in Homming problems for openPNP:
Thanks for reply.
Sure
Thanks! The wiki page is at https://duet3d.dozuki.com/Wiki/Using_RepRapFirmware_with_OpenPnP. Let me know your name on the wiki and we'll increase your reputation score sufficiently to edit it.
I don't understand the name, sorry but English is not my native language.
Jose
You will need to go to the wiki page, then click Login at the top right. This will allow you to create a Wiki account. When you have done that, let me know what user name you chose.
Done, same name.
I wrote a test now.
@qlfecv, you now have enough reputation to edit that wiki page.
