Moisture sensor / Hygrometer
  • Hi,
    has anybody successfully attached a hygrometer to any duet board? I am thinking about this to have a moisture-sensor/hygrometer go to the filamentbox to throw a warning if there is too high humidity for a certain material. The max level (threshold) what is too high could be individually stored in the "filaments" on the duet. Though that would mean you cannot just post any g-code file from a third party slicer but also have to make sure the same filament is selected on the duet...
    Any ideas?
    Lucas
    Duet/RRF supports the DHT temperature and humidity sensor.
  • @dc42
    First - thanks for answering so fast!
    Great!
    Searching the forum for "DHT" or "DHT11"/"DHT22" did the job!
    Solved - thanks!
