AJAX timeout error during a print
Two hours without disconnects or connection freeze using latest 1.16 release firmware with @chrishamm web-server 1.03-ch firmware. Still looking at error logs, but it seems that this release is much stable.
Firmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.16 (2016-11-08)
WiFi Server Version: 1.03 (ch fork)
Web Interface Version: 1.13 -
Seems like DWC connection freeze issue fixed. Three hours yesterday and one hour today without any connection freezes. Thank you!
That's great, thanks for confirming that my latest improvements are working well!
Hi
I'm new here and building 3d printer in my free time.
I just set up a Duet v0.6 with the latest firmware and Web Control:
Firmware Name: RepRapFirmware for Duet-0.6-0.8.5
Web Interface Version: 1.13After connecting to the duet via Web Control I'm getting the same error like appjaws after ~55 secconds while doing nothing:
Communication Error
An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again.
Error reason: timeoutI reestablished the connection several times and got the error message every time after 55 secconds.
Thanks for every hint and help. Just tell me if you need further information.Edit: I'm using windows 7 pro and the error appears in Firefox and Chrome
I recommend you try to reset your TCP/IP stack once and restart your computer, see https://support.microsoft.com/en-us/kb/299357
Well that solved the problem fast and perfect. Thank you!
@dc42 : spam?
